Air/Fuel Gauge
I would like to know which wire do I have to splice from the 02 sensor. I would like to connect directly to 02 sensor rather than the ECU. The 02 sensor has 4 wires 2 blacks a green and white wire. Any help would be appreciated.
There are four wires. Two blacks are the heater circuit. Signal wire is the one you want, I don't remember if it's white or green, but check for continuity to the chassis ground on each one to pick out the ground.
yurvn
May 25, 2004 07:30 PM
2000_Si_On_Air
Jul 6, 2002 06:35 PM
