FS: B and D series, civic, integra, turbo parts, ITR, GSR
I have alot of stuff i need out of my way.
Civic Parts:
97 d series motor mounts $40
96-00 civic complete a/c system $80
96-00 civic heater core $50
96-00 civic climate doors w/ actuators $50
92-00 front hubs with calipers and rotors uncut brake lines $50each or $75 both
92-00 rear trailing arms with drums and uncut brake lines $50 each or $75 both
92-00 rear upper control arms $20
96-98 4 dr tail lights uncracked un scratched $75
96-00 4 dr trunk lid silver $80
96-00 4 dr tail light skirt $30
96-00 4 dr front door shells $30 each or $50 both
96-00 rear bumper support $20
96-00 front lower control arms $30
96-00 front upper control arms $30
96-00 power steering steering rack with good tie rods and tie rod ends $70
power steering resevior $15
96-00 civic dash grey $120
96-00 4 dr carper grey $100
96-00 front seats grey $60 no rips or tears
96-00 rear seats grey $60 no rips or tears
96-00 4 dr head liner $50 no rips burns or tears
96-00 4 dr door panels $40 each or all for $100
96-00 4 dr front and rear and quarter glass $75
96-00 4 dr rear deck tray $50
96-00 4 dr rear padded frame $30 each or $50 for both
96-98 cup holder w/ tape player $40
96-98 tape player $20
96-00 headliner trim pieces $10 each or $50 for all
96-00 Steering column w/ key $60 (will include other locks for doors, trunk, rear deck key, and lock for the release **** for $100 total)
96-98 4 dr chassis harness $50
96-00 4 dr seat belts $30
96-00 fuel tank $50 w/ pump
96-00 sub frame $50 w/ anti sway bar
ITR Head Package:
8 intake inner valve springs
8 intake outer valves springs
8 intake valves
8 exhaust inner valve springs
8 exhaust outter valve springs
8 exhaust valves
8 hydrolic loss motion assemblies
16 retainers
these parts have about 15k on these no bent valves. sold my last package for $160 SHIPPED
Turbo Parts:
OBD1 Xenocron ZIF socket'd chipped P28 w/ 4 pin datalog port $150
Moates HuLog $20
2 1/16th (52mm) Auto Meter Ultra Lite -30/20psi boost gauge w/ hardware and backlight socket $35
2 1/16th (52mm) Auto Meter Ultra Lite Oxygen(O2) LEAN, STOICH., RICH narrow band gauge $35
Greddy TYPE S knock off Blow Off Valve $25
Blitz Dual Drive Blow Off Valve $65
Misc:
d15b7 intake manifold $25
Flowmaster 40 series 2.5" inch center to offset $35
94-01 integra AutoMeter dual gauge pod $35
94-01 integra M3 mirrors with L.E.Ds $35
94-01 integra rear trim between tail lights and bumper $25
94-01 integra a/c system minus the drier $75
94-97 integra OEM drivers side bumper light $10
94-97 integra OEM rear bumper (small crack) $30
94-97 integra OEM front bumper (lots of cracks) $15
96-97 integra fuse panels, abs computer $20 for all
98-01 integra Extreme Dimensions XTREME rear bumper $60
98-01 integra crystal clear bumper lights $30
96-00 civic coupe drivers door shell (scratch and small ding, looks like a ball peen tap) $30
96-00 civic drivers door harness $25
96-00 civic drivers window regulator $25
96-00 civic drivers door lock actuator $20
96-00 civic drivers door handle NH592P $20
96-00 civic dx/lx wheel hub $35
USDM pr3 pistons (less 1kmiles) .020" over (81.5mm) $40
90-93 integra cv axle $20
92-00 civic d series shifter stiffener bar with energy susp. bushings $20
92-00 civic (2) radiator fans $25ea
94+ rear bumper support $35
dc/eg cruise control module $20
dc teg front splash guards $60
99-00 civic 00-01 integra 98-99 2.3CL 98-02 4 cyl accord Xenocron OBD2B-OBD1 conversion harness $60
96-01 GSR intake manifold w/ sensors and throttle body OBD2 $120
98-01 GSR camshafts great for turbo $120
I think this is everything IF NOT ill be adding more so keep checking in.
Pm me what you want or need and your zip and we will go from there.
Civic Parts:
ITR Head Package:
8 intake valves
8 exhaust valves
16 retainers
Turbo Parts:
Moates HuLog $20
Misc:
Last edited by 98GSR-Turbo; Mar 26, 2011 at 02:49 PM. Reason: parts are selling quick
