started then died need ideas
Old Feb 27, 2011 | 07:50 PM
brokenagain's Avatar
Default started then died need ideas
90 honda accrod ex 2.2 started then died. Had no spark then replaced main relay, now it has spark but still won't start. Car turns over slowly and kinda chugs.... not normal. Ecu fuses good. Spark at the plugs. Tining belt has tension I can hear the fuel pump in the gas tank..... I have no idea
Old Feb 27, 2011 | 09:16 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: started then died need ideas
Did you check the battery? It could be dying.
Old Feb 27, 2011 | 11:13 PM
I put a battery charger on it and charged it with the same results.
mcr1971
Jul 17, 2017 05:24 AM
xXViperXx
13
Jan 14, 2015 09:31 PM
hamburgler
Aug 21, 2011 10:23 AM
TheTealHatch
13
Oct 15, 2008 04:02 AM
Solo1
Feb 17, 2004 01:57 PM
