safc
with the apexi safc, are there only 5 wires that needed to be spliced? and i was reading the instructions on the apexi site for the safc, would the pins be the same for the ef9 w/ b16 and my usdm ed7? thanks
Guest
Posts: n/a
yeah pin numbers are the same. ook up the wires like the diagram says. you can hook up the blue wire to the o2 sensor to read a/f from it. to do that go to settings -> etc-> sensor check. its under IN-2 will display in volts. .5-.6 is a stoich mixture. higher is more rich lower is more lean
