1995 accord- weird problem
The other day I was driving down the street and one of my spark plug wires popped out. Turns out the spark plug snapped in half. I replaced all the spark plugs and it ran fine for about 10 mins until it started losing compression and the engine started jolting. It seems like one of the cylinders isnt firing and i dont know why. Everything is hooked up theway it should be. Any ideas??
I unplugged all the wires from the distributor and checked for corrosion this morning. None of them seemed to be damaged or corroded. I was driving it around last night and it was fine up until when I gassed it kinda hard and then I lost power and I felt some vibration from the pedal
Perform a compression test. If pieces fell in and caused enough damage to create misfires you'd see the results in a compression test.
Keep an open mind, though. Lots of things can cause misfires.
FTNW
Dec 7, 2010 01:10 PM
