Suspension & Brakes Theory, alignment, spring rates....
96 spec Integra Type-r caliper rebuild kit part#'s
Old Feb 27, 2011 | 01:26 PM
4dooreg-k's Avatar
Default 96 spec Integra Type-r caliper rebuild kit part#'s
Can anyone confirm that these are the correct part numbers for the rebuild kits for 96 spec Integra Type-r front and rear brakes?
01463-SV4-000 front
01473-SV4-000 rear
Old Feb 28, 2011 | 10:07 AM
BlueIntegraBoy's Avatar
Default Re: 96 spec Integra Type-r caliper rebuild kit part#'s
Those are for 98 spec ITR (or any 5-lug ITR)
96 spec ITR uses regular Integra calipers, so part numbers for the seal kits are below:
01463-ST7-000 CALIPER SEAL KIT, FR.
01473-ST7-000 CALIPER SEAL KIT, RR.
Old Feb 28, 2011 | 02:42 PM
4dooreg-k's Avatar
I know the rears are the same as rs/ls/gs but the fronts are larger.
Old Feb 28, 2011 | 02:45 PM
Check the stamp of the caliper.
17CL15VN = Larger 5-lug ITR caliper (Rebuild kit 01463-ST7-R00)
17CL14VN = 96-spec ITR caliper (Rebuild kit 01463-ST7-000)
Old Feb 28, 2011 | 03:16 PM
4dooreg-k's Avatar
the itr 4x114.3 calipers are stamped 17CL15VN and so are the 4x114.3 prelude calipers i have.
so its 01463-ST7-R00? not 01463-SV4-000?
Old Feb 28, 2011 | 03:20 PM
So you did a 282mm upgrade on your 96 spec ITR brakes?
The SV4 part number got superseded by the ST7 number. The ST7 is current.
Old Feb 28, 2011 | 04:38 PM
4dooreg-k's Avatar
didnt know they were upgraded. bought the 4x114 conversion like that. which doesn't make much sense either because if the 96 spec itr had the same front caliper as other integras wouldn't they also have the same knuckles as well? so the 98spec calipers wouldn't just bolt up to the 96 spec knuckles. you would have to shave the caliper bracket for them to fit. and the ones i have are not shaved. and i doubt someone pressed in 96 4x114 hubs into 98 spec knuckles. thanks for the info btw.
Old Feb 28, 2011 | 04:50 PM
96 spec brakes are the same size as regular Integra, even share the same knuckle. You can upgrade the brakes to 282mm by using Prelude VTEC rotors, 17CL15VN calipers with 25T brackets (or 23T brackets with washers to shim). It all bolts up. 98 spec knuckles are different, use a larger wheel bearing than any other Integra (including USDM ITR).
Old Feb 28, 2011 | 04:56 PM
4dooreg-k's Avatar
ok, so i guess i bought them with the front calipers/brackets upgraded.
Old Feb 28, 2011 | 06:34 PM
roastbeefrichie's Avatar
good info BlueIntegraBoy
FRONT BRAKES
on your 96 ITR spec 4X114.3, from the factory come standard w 17cl14vn calipers on 10.3" front rotors (which can be found on any 94-01 integra 4X100)
you have the 17cl15vn on 11" front rotors, which are found on the 5-lug ITR.
the 17cl15vn caliper is one of the biggest single piston honda produces.
nice lil upgrade in the front, good find!
REAR BRAKES
this might help you identify your rears:
the stock 96 ITR spec rear calipers w 9.4" rear rotors are stamped 7CLP13S (also found on any 94-01 integra 4x100),
the 5-lug ITR, uses a larger caliper stamped 9CLP14S w 10.2" rear rotor
Old Feb 28, 2011 | 06:37 PM
4dooreg-k's Avatar
this info should be in the FAQ
Old Feb 28, 2011 | 07:19 PM
I'd like to add that 17CL15VN calipers also include the NSX, Legend, and ATR calipers. They are all 2POT and use the same pads as any other 17CL15VN caliper (which can be found on Prelude, Accord V6, CRV, Odyssey, etc.).
Jgreen94
Northeast (Sales)
Aug 23, 2013 02:55 PM
95lscivic
Dec 10, 2010 03:09 PM
xlasianizelx
Northern California (Sales)
Jan 23, 2010 02:20 PM
