what is this hose called that burst? *pics*
I came home and smoke was pouring out of my hood. This hose had 2 holes with steam or something shooting out. It looked like it was radiator coolant all over and it melted the paint off. what hose is this
anyone have a part number?
Uploaded with ImageShack.us
Sorry, I don't have a part number, but you can just go to a parts store a buy a section of hose with the correct ID (inner diameter) and pressure rating. That is not a factory part. Either yourself. or the previous owner had an aftermarket intake on the car.
Looks like the hose that runs to the bottom of the TB. It supplies coolant to the TB so it doesn't stick in cold weather and I'm sure it supplies the coolant to the IACV as well. Like Kyle R said, you can just go to any auto store and they should have it. Just bring the hose with you or see what size it is; should say on the hose.
don't forget to bleed the air pocket out of the cooling system, there should be TWO bleeder valves(one near the block and one by the firewall with a rubber cap), refill coolant if needed.
boostincoupe
Jul 23, 2006 11:17 AM
