Need opinion on main and con-rod bearings PIX included
Old Feb 26, 2011 | 12:19 PM
qpe's Avatar
qpe
Default Need opinion on main and con-rod bearings PIX included
recently my engine started making strange knock- sound, as I'm going to change oil pump I decided to check the bearings by the way, its h22a
so here it is, the 1st one is one two pictures, they look fine for me?
I'm more concerned with some of con rod bearings there are strange looking spots on them. I will replace them anyway but would the spots cause knocking sound hmm probably not 7
let me know what do you think
Old Feb 26, 2011 | 02:23 PM
rudebwoy's Avatar
Default Re: Need opinion on main and con-rod bearings PIX included
too much clearance
Old Feb 26, 2011 | 05:37 PM
MR.johnson's Avatar
check clearance and give us the numbers...
Old Feb 27, 2011 | 03:11 PM
qpe's Avatar
qpe
main bearing clearance
1 - 3 0.045mm
4 0.035
5 0.035
I'll check con rods later. This is pretty fresh build there is about 3000miles on it and there were no any knock before, clearances were checked too
Old Feb 28, 2011 | 04:25 AM
kyden's Avatar
those are huge clearances.
Old Mar 1, 2011 | 01:04 AM
qpe's Avatar
qpe
they are in mm and according to user manual they are fine,
have you noticed these strange looking spots on con rod bearings, shall I replace them or its fine ??
Old Mar 1, 2011 | 11:28 PM
qpe's Avatar
qpe
bump
willfly
Jul 8, 2013 03:00 AM
EFz6er
Jan 28, 2013 05:20 AM
Marcpb443
Nov 3, 2006 01:00 PM
godsider
Feb 25, 2006 03:03 PM
