94 Integra Part Out *South Central PA* Pedals/Clutch Reservoir for 5 speed swap
Old Feb 26, 2011 | 11:10 AM
delslo93's Avatar
Default 94 Integra Part Out *South Central PA* Pedals/Clutch Reservoir for 5 speed swap
Hey everyone, I have a few parts left from the Integra I have been parting out. I am located in south central PA about a half hour south of Harrisburg. If you are interested in anything PM me or feel free to text me at 717-385-7498. Thanks for looking.
Door Panels $45 for the pair.
Or I am willing to part them.
Drivers Door Panel. $30
Passenger door Panel. $20. It is missing the window switch and part of the fabric is starting to come off. Should be a pretty simple fix of just re-adhering it.
Drivers Door. There is a small dent under the handle should be. Otherwise pretty decent shape. No noticeable rust. $45
Passenger Door. There is a few dents by where the handle is. No noticeable rust. Again, pretty decent shape. $40
Pedals and Clutch Reservoir for 5 speed swap. Good condition, no leaks. $50
Headlights. They are a bit hazy so they will need to be wet sanded and buffed. There is also a little over spray on the bottom side of them that isn't noticeable when the bumper is on. There are no cracks on the lenses or on the mounting tabs. $40 for the pair.
Drivers side fender. No dents. Nice shape, will need paint. $30
15/16 Master Cylinder and Brake Booster. Works fine no leaks. $35
This is the complete interior harnesses. This goes from under the front doors to back to the rear hatch and tail lights. $40
This is the sunroof harness. $20
Under hood fuse box. $25
Under dash fuse panel. $25
Steering Column. There is no ignition but everything else is there and in working order. $30
Seat Belts. All of them work properly as far as I know. $25 for all of them.
Cruise Control Module. $15
Windshield Motor. Still works fine. $20
Hatch Shocks. Still work perfectly. $25
Throttle Cable for LS engine. I'm not sure what all else this will work on. Still in great shape. $15
Door Sills. Pretty decent shape with just normal wear. $15
OEM Floor Mats. Pretty dirty but would probably clean up decently. These would be great for secondary mats to your good show mats. $20
Windshield wiper motor cover. There a slight crack by the one mounting hole but nothing real noticeable. $10.
Old Feb 28, 2011 | 02:17 PM
delslo93's Avatar
Default Re: 94 Integra Part Out *South Central PA* Pedals/Clutch Reservoir for 5 speed swap
ttt
Old Mar 1, 2011 | 06:13 AM
xtremeness101's Avatar
If you have a right front inner fender lining i will take it.. let me know how much shippied to NY 11769 thanks
Old Mar 1, 2011 | 08:06 AM
delslo93's Avatar
Sorry man sold those things. If you don't see it in the list I don't have the things anymore.
Thanks for the bump!
Old Mar 2, 2011 | 08:02 AM
delslo93's Avatar
Come on I know some one wants these things
Old Mar 3, 2011 | 08:24 AM
delslo93's Avatar
bump
Old Mar 5, 2011 | 07:58 PM
delslo93's Avatar
Bump
Old Mar 6, 2011 | 06:59 PM
delslo93's Avatar
Bump
Old Mar 10, 2011 | 08:18 AM
delslo93's Avatar
bump.
ndccpf1
Oct 19, 2018 01:17 AM
delslo93
Mid-Atlantic (Sales)
11
Mar 11, 2011 08:57 AM
Ch33se
Sep 20, 2003 10:55 PM
