Will a EG or EK steering wheel fit on a CRX without a hub?
Old Sep 25, 2002 | 09:03 PM
T_Rex's Avatar
Default Will a EG or EK steering wheel fit on a CRX without a hub?
I need to replace my steering wheel and I want a Honda one that I can just swap out, without having to buy a hub.
Will an EG or EF steering wheel work? If not, are there other Honda ones that will? Thanks.
[Modified by hondanut, 11:29 AM 9/29/2002]
Old Sep 25, 2002 | 09:20 PM
civicrtype's Avatar
Default Re: Will a EG or EK steering wheel fit on a CRX without a hub? (hondanut)
The EK and EG are different. The EK hub is a little bigger than an EG's, but don't know if either one work wit ur CRX. Go to http://www.momo.com and check if the part #'s for the EG or the EK is the same as yours. If it is then one will work. I know EK's are #4920 and EG's are #4911.
Old Sep 25, 2002 | 09:43 PM
T_Rex's Avatar
Default Re: Will a EG or EK steering wheel fit on a CRX without a hub? (civicrtype)
Thanks for the info man, but that site doesn't give any info on the part #s. You're talking about http://www.momo.it right?
It's really general and only shows pictures of the different steering wheels.
Old Sep 26, 2002 | 05:42 AM
civicrtype's Avatar
ya actually I saw the part number on another site and I thing 88-91 Civic/CRX are #4905 so neither will fit unless you change out the whole steering rack. Good luck....1.
Old Sep 26, 2002 | 07:33 AM
Mugen Dom's Avatar
it should bolt on ive seen jdm type r ones on EF's before
Old Sep 26, 2002 | 12:47 PM
T_Rex's Avatar
Default Re: Will a EG or EK steering wheel fit on a CRX without a hub? (JdMB16Ahatch)
Has anyone done it or know for sure?
Old Sep 26, 2002 | 03:07 PM
Francois's Avatar
They say they fit.
The only problem,is,your gonna see a gap between the steering column and the steering wheel.
Old Sep 26, 2002 | 09:08 PM
T_Rex's Avatar
Default Re: Will a EG or EK steering wheel fit on a CRX without a hub? (Francois)
up
Old Sep 26, 2002 | 10:19 PM
civicrtype's Avatar
Well I know that when I put my EK steering wheel on my friend's EG it did not fit cause my hub was too big and the teeth on the hub did not even touch, and they are suppose to be tight. His EG steering wheel did not even fit at all since the hole on his hub is alot smaller. Check the EG forum peeps know. And trust me since EG and EK are different I am almost positive that the EF's are completely different. If all three use different MOMO hubs thats because the size of the steering columns are different. The only way you can make it work is if you change the column. I am 99% sure.
Old Sep 26, 2002 | 10:22 PM
civicrtype's Avatar
oh ya when I get a chance I will try my EK hub on my EF this weekend and I'll let you guys know...........1
Old Sep 26, 2002 | 10:27 PM
Mugen Dom's Avatar
DA integra will fit same splines so EG should fit also...mugenef7 has a mugen wheel with teh EG hub i believe
Old Sep 29, 2002 | 10:13 AM
T_Rex's Avatar
Old Sep 29, 2002 | 10:28 AM
primoEF's Avatar
I think the shaft sizes are different
MiniTrev
Feb 20, 2013 05:24 AM
ja20_eg
Feb 4, 2009 11:51 AM
hialeahzbg
Jun 9, 2007 01:17 PM
Urugly
Apr 1, 2006 10:19 AM
T_Rex
Sep 25, 2002 10:04 PM
