where to buy perforated tubing?
Old Feb 25, 2011 | 12:07 PM
weiRtech's Avatar
OG Fabricator
Default where to buy perforated tubing?
anyone have a source for perforated tubing, the kind you find in mufflers? i've been making mufflers for a couple years now with perf tube big enough for 2.5" tube to slide inside it and my source (a local exhaust shop) has finally run out of material - because i basically used up everything they had.
Old Feb 26, 2011 | 07:02 AM
-RedneckDave-'s Avatar
Working
Default Re: where to buy perforated tubing?
You could talk to 9bells, but I believe he buys his in sheets and forms his own perforated tubing.
Old Feb 26, 2011 | 07:31 AM
Tjabo's Avatar
Do you have a source for high temp sound absorption material?
Sorry, I can't help with the source for the perforated tubing, but I too am interested! (subscribed to thread!)
EDIT: I wonder if Vibrant would sell some? Theirs is nice and open (high void ratio or hole ratio?). Magnaflow's is nice, but seems a little less highly perforated.
Old Feb 26, 2011 | 08:12 AM
weiRtech's Avatar
OG Fabricator
i've found a source for the tubing locally, i just have to run over there and see if their stuff is close to what i'm using now.
as for packing, i just use normal glass pack i get from the same exhaust shop i was getting the perf from.
Old Feb 27, 2011 | 04:20 PM
c5R's Avatar
c5R
http://www.perforatedtubes.com i used to work for a company that used these guys for all there perforated tubes for filter elements. this place can make tubes out of any material any size and perforation pattern. give them a call they may have over run or scrap that will fit your needs
quik sol
Aug 18, 2015 01:52 PM
ATSMATT
Welding / Fabrication
Nov 8, 2010 01:34 PM
90Rexx
Mar 1, 2010 05:15 PM
Zornig
Apr 24, 2006 08:08 PM
VtecAdil
11
Jul 15, 2005 01:40 PM
