*****Massive Garage Sale! Cheap prices, B and H series parts! 56k Go bake a cake****
Old Feb 25, 2011 | 11:52 AM
H25's Avatar
H25
Default *****Massive Garage Sale! Cheap prices, B and H series parts! 56k Go bake a cake****
Hey guys and gals. It's about that time again to make room in the garage. Let me know what you're interested in and I will give you a good price... Or feel free to shoot me an offer!
All parts can be picked up in OC or shipped.
Thanks for looking!
Box full of ecus. Obd0 b16a, pr3, pwo, obd1 p06, p14, obd2 pct, and other sohc ecus. Some of the obd0 ecu have a check light. I rather not sell them individually because I'm trying to make room. I'm only asking $40-$60 for any ecu. I will give deals if you buy more
B16a valve cover
BDL 70mm throttle BNIB $265shipped!
B series axles and half shaft $120 plus shipping
Passenger side B series axle $35, 1 D series passenger side axle $25 B series cable type half shafts $50 H22 aluminum body half shaft $60
Simpson titanium color 4 point harness with camlock SOLD!! B16a and h22 cams $40 each pair, 94-00 gsr rear engine bracket SOLD 99 civic si cruise control $20 99 civic si shifter SOLD B16 or LS oil pickup $20 AEM brute force intake pipe for 00-04 tundra v8.
99 civic si clutch master cylinder with reservoir $20
99 civic si cup holder $20
98 GSR head studs $40 Perfect for LSvtec or B20vtec
h22 obd1 alternator
f20b valve cover cut for cam sprockets $50 B or D series dual bend short shifter SOLD 94 gsr brake booster and reservoir $60 B series clutch fork SOLD B series pulley $20 vtec solenoid $20
b series cam caps and oil spray bars $20 Iac valve $20 B16 cable gear set good. $50 B series slave cylinders $10, 99 civic si front forks $20 B series mount kit for EF $20 Power cable $10
B series 4.40 final drive 66 tooth ring gears and final drives. $40
H series tranny bracket $10 h22 alternator $20 h series tranny cable bracket $10 random B or H series gear set $20
2000 civic si brake booster and reservoir $50!!
ACL engine bearings $20
H23 stock rods $40
h22 starter $20
h23 oil pickup $20 h23 manual tensioner $20 h23 rods $40
obd2b-obd2a jumper harness SOLD
2000 civic si battery tray $20
89 crx si battery tray $20
2009 G37S muffler SOLD
H22 dual valve springs and retainers $40
NX wet kit with purge system, honda bolt on fuel line with t fitting, hoses. Just need fogger nozzle and bottle. $120
civic si dual core radiator with fan and lower B series radiator hose $60!
B and H series stock valves $30
h22 shift cables brand new $120
Box of 10mm bolts with a few others $10
92-95 civic center console and shift boot cover with cup holders $30
map sensor $20
More pictures of the NX kit and some other stuff....
http://hondamarketplace.com/showthread.php?t=2898778
Old Feb 25, 2011 | 12:02 PM
H25's Avatar
H25
Default Re: *****Massive Garage Sale! Cheap prices, B and H series parts! 56k Go bake a cake*
up
Old Feb 25, 2011 | 12:10 PM
sh!ft's Avatar
Who the fack changed my title?!
im wanting to know some info on the following parts:
scatter shield(what series is it for?)
gauge by the harnesses
bearings(size)
mainshaft gear assembly(what series)
ring gears
countershafts
teh flare!
Old Feb 25, 2011 | 06:13 PM
H25's Avatar
H25
bearings(size)
ring gears
countershafts
teh flare!
Scatter shield is for an H series
I think you're referring to the autometer ultralite series silver face water temp gauge.
ACL engine bearings standard size
B series main shaft. I also have a counter shaft for it as well
Ring gears I think they are H22 4.266. If they are B series they would be 4.40. Sorry, it's been a while since I looked. I would have to research it further if you're really interested.
What about the flare?
Thanks for your interest in my parts. Let me know if you have any other questions!
Old Feb 25, 2011 | 08:45 PM
H25's Avatar
H25
ttt
Old Feb 25, 2011 | 09:19 PM
mikesaba's Avatar
are those k series shifter cables? if so please pm me price shipped to 07305 thanks alot
Old Feb 26, 2011 | 01:13 AM
H25's Avatar
H25
2000 prelude vtec shifter cables
I have a dc5 shifter box for 60 if you're interested?
Old Feb 26, 2011 | 10:01 AM
H25's Avatar
H25
ttt
Old Feb 26, 2011 | 10:42 AM
will_quach's Avatar
what jumper harness is that? brand?
Old Feb 26, 2011 | 11:05 AM
H25's Avatar
H25
99-00 chassis to 96-98 ecu. Works good, Doesn't say.
Old Feb 26, 2011 | 06:01 PM
will_quach's Avatar
so obd2b - obd2a?
Old Feb 26, 2011 | 08:23 PM
H25's Avatar
H25
so obd2b - obd2a?
yes
Old Feb 26, 2011 | 10:35 PM
kingofbattle909's Avatar
WOAH...
Old Feb 27, 2011 | 10:05 AM
H25's Avatar
H25
Morning bump
Old Feb 27, 2011 | 12:40 PM
BUMP
Old Feb 27, 2011 | 10:11 PM
H25's Avatar
H25
ttt
Old Feb 28, 2011 | 12:11 AM
Geo914's Avatar
how much for jdm road flare?
Old Feb 28, 2011 | 01:38 AM
H25's Avatar
H25
20
Old Feb 28, 2011 | 01:58 AM
H25's Avatar
H25
JDM flare SOLD!
Old Feb 28, 2011 | 09:02 AM
H25's Avatar
H25
ttt
Old Feb 28, 2011 | 04:37 PM
bump
Old Feb 28, 2011 | 09:52 PM
touge_terror's Avatar
I doing a a g23 build an I have a bare h22 head that I'm putting together. I need pretty much all the hardware for the head. How much for the valve cover, crank pulley? what else you got for H22 ect.
Old Mar 1, 2011 | 12:51 AM
H25's Avatar
H25
Nice, I hear those g23's make good power! Here is what I know I have for sure.
ac auto technik h series scatter shield $60
jdm h22 cams for 60 bucks
f20b valve cover for $50
Jdmh22 dual valve springs, retainers for $40
jdm h22 crank pulley for $20
jdm h22 exhaust manifold with flex pipe for $60
h23 manual timing belt tensioner for $20 with the hardware
shot peened h23 rods never installed for $60
h22 euro R rods with 3 good pistons (p5p) They are 11.5:1 compression $80
h22 oil pickup $20
h23 oil pickup $20
h series oil pan $40
h22 diff $60
Not pictured
2000 h22a euro R aluminum intermediate shaft (half shaft) very low miles in very clean condition $120
I may have some other parts too.
Old Mar 1, 2011 | 11:05 AM
H25's Avatar
H25
B series cable and hydro rear engine brackets $40
rear brackets will work for the following vehicle setups
85-91 civic/crx with B series
90-93 integra with B series
94-00 civic with B series
96-00 civic with B series
Old Mar 1, 2011 | 11:10 AM
*JDM*Ej8*'s Avatar
Ship out today?
