gas in oil. new rings? input ?
Old Feb 25, 2011 | 07:47 AM
h22accordian's Avatar
Default gas in oil. new rings? input ?
I have a 94 h22a accord. The motor is built and I have a garrett turbo. She makes 430whp on 12 psi. Ok well the car ran on 505 hp daily for a few years. Well it has an idling problem and iits getting a lot of gas in the oil making it water thin. I did a compression and leakdown and cyl one and three we're off way off I can post results if needed. Should I go ahead and rebuild the motor. Oh and the motor is sleeved and ir idles at 25-28 when cold. What should my rebuild consist of? New pistons rings. Main bearings. What else? And anything I can do right now?
Old Feb 25, 2011 | 08:23 AM
hondamark35's Avatar
Default Re: gas in oil. new rings? input ?
i'm no expert... but in my experience an abundance of gas in the oil would be a fuel problem not a ring seal problem. worn rings would leave excess oil on the cyl. walls causing oil consumption/burning, and/or poor and inconsistent compression/leak-down numbers.
but, if you're dumping too much fuel it will wash down the cylinders past the rings causing the rings to wear prematurely (gasolines lubrication qualities are nothing compared to oil... )
hope that helps.
Old Feb 25, 2011 | 11:16 AM
nus_dogg's Avatar
Why don't post up the results you got from the compression & leakdown test and I'll be able to tell you.
Old Feb 25, 2011 | 05:36 PM
phootbag's Avatar
hope that helps.
Poor sealing between the rings and cylinder can allow some of the fuel/air mixture to bypass during compression and drop below the piston into the oil supply.
Old Feb 27, 2011 | 11:52 PM
Ok here's the results...
Compression test 1-170 2-195. 3-185. 4-200
Leakdown - 1-25% 2-5% 3-19% 4-0%
Old Feb 28, 2011 | 02:17 PM
phootbag's Avatar
Do the results change when lubricating the cylinders with oil?
Old Feb 28, 2011 | 10:42 PM
Yes. To what they are now
KyoCivic98
17
Aug 21, 2009 04:21 AM
j0keefe21
11
Jun 22, 2009 04:20 PM
Blk-dc2
Feb 25, 2007 09:59 PM
GDM Z28
Feb 1, 2005 04:33 PM
Wazup
May 1, 2003 06:51 PM
