92 eg ls swap????
Old Feb 25, 2011 | 12:19 AM
eghatch90's Avatar
Icon2 92 eg ls swap????
During this upcoming summer im planning on swapping in an ls out of a 94 integra, from what i have gathered its basically a drop in swap with a hydro shift trans/cvc's and what not. im planning on going with a p28 due to all the available tuning options. this is my first swap but im heading into it with confidence. any info from others that have previously done this swap would be much appreciated. thanks tons.
Old Feb 25, 2011 | 08:18 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: 92 eg ls swap????
DO NOT USE THE P28 ecu. Get a P75 (LS) and everything will run the way it supposed to.
Old Feb 25, 2011 | 11:01 AM
kyyos24's Avatar
youll also need a straight pipe or an ls cat for the exhaust to bolt up right
Old Feb 25, 2011 | 12:31 PM
Crashtestdummy's Avatar
I did the ls swap on a different hatch of mine, did just what NVturbo said and it worked beautifully. Its good your starting out with the hydro tranny cause i started out with a cable one and it was a pain. Wound up switching to hydro after only a month. If you plan on having ac tho you gotta get a compressor bracket off a del sol or crv i think was what i had to use. Thnx to other honda tech members that saved me from sweating my *** off during the summer. Good luck with the swap
Old Feb 25, 2011 | 02:18 PM
NVturbo's Avatar
O.G. triple O.G.
^^^ almost correct. For A/C connection with a B-series swap, you have to acquire one from a B16 Del Sol DOHC VTEC. They sell the brackets for around $60+, while using the stock Civic compressor, lines, etc.
eghatch90, since you have the motor out, do yourself a favor and replace the timing belt, water pump, belt tensioner, front main seal (oil pump seal), rear main seal (behind the flywheel) along with the clutch. It is 1000000x easier to do all this work when the motor is not in the car.
Andrew14
20
Jun 27, 2010 06:22 PM
rrroy6495
May 22, 2009 07:04 AM
integraguy17
Feb 3, 2004 07:31 PM
gixxer6
11
Nov 6, 2002 07:22 PM
