Headlight,turning signal & indash problem
welll im having problems with my headlights wont work nor turning signals or in dash but my reverse and brakes wrk and its not a relay or else my brakes wouldnt wrk or reverse and all my fuses are all goood but see when i turn on my alarm my turning signals go off and my in dash lights up idk whats the deal some pple told me its the head light switch?
Did you check "ALL" fuses or just the ones you thought wore for the lights? Check under the hood fuses and all bro. If all is good,the switch might be bad.
yeah i checked all the ones from my hood and under and they are all fine !
they jst wont come on but do when i turn on and off my alarm my turning signals and indash work ive checked bulbs and they're fine
Yeah well it might be a bad switch or relay. The tails have its own relay if I'm not mistaken? It might even be a loose wire under the dash.
Silvertune
11
Apr 15, 2012 09:20 PM
