FS: Running JDM B18C Short Block with CTR(PCT) pistons, part-out ok
Old Feb 24, 2011 | 04:24 PM
JerseySiPOS's Avatar
Default FS: Running JDM B18C Short Block with CTR(PCT) pistons, part-out ok
I have a running JDM B18C short block for sale. It was originally a GS-R block but I rebuilt it in 2007 with 81mm Civic Type-R (PCT) pistons. The whole block has has 17k miles, but has basically a new OBD2 oil pump with only two oil changes since I installed it. The pump has the CKF sensor slot so no wire tricks or splicing is needed to run an OBD2 ECU. It was rebuilt with a machine hone, new bottom-end gasket kit, piston rings, bearings, thrust washers, oil separator grommets, CTR (PCT) pistons pressed onto P72 rods and micropolished crankshaft. I also have the nuts and washers for the AEBS head studs which has been used 3 times. Can be used as a running block or I can part out for serious buyers only!!! Asking $700 complete.
Please send me a private message if you are interested and/or have any questions.
Located in Central NJ by Raceway Park.
- ilija
Old Feb 24, 2011 | 05:34 PM
goldhatch94's Avatar
Default Re: FS: Running JDM B18C Short Block with CTR(PCT) pistons, part-out ok
2 oil changes in 17k miles? thats not good info to put but bump good luck looks like a killer set up
Old Feb 24, 2011 | 07:15 PM
beelzebub's Avatar
I think he was only referring to the new oil pump.
Old Feb 26, 2011 | 04:26 AM
About 6000 miles on the oil pump, 2 oil changes. was unclear, sorry.
JdmTosca
Northeast (Sales)
Oct 28, 2011 09:44 PM
JerseySiPOS
Northeast (Sales)
Jul 15, 2011 11:02 AM
Mr.Milton
Jun 24, 2009 09:25 AM
hndacord02
May 11, 2007 07:09 AM
kuki
Nov 29, 2006 04:23 PM
