FS: Running JDM B18C Short Block with CTR(PCT) pistons, part-out ok
SOLD to JdmTosca
I have a running JDM B18C short block for sale. It was originally a GS-R block but I rebuilt it in 2007 with 81mm Civic Type-R (PCT) pistons. The whole block has has 17k miles, but has basically a new OBD2 oil pump with only two oil changes since I installed it. The pump has the CKF sensor slot so no wire tricks or splicing is needed to run an OBD2 ECU. It was rebuilt with a machine hone, new bottom-end gasket kit, piston rings, bearings, thrust washers, oil separator grommets, CTR (PCT) pistons pressed onto P72 rods and micropolished crankshaft. I also have the nuts and washers for the AEBS head studs which has been used 3 times. Can be used as a running block or I can part out for serious buyers only!!! Asking $700 complete.
Please send me a private message if you are interested and/or have any questions.
Located in Central NJ by Raceway Park.
- ilija
- ilija
JerseySiPOS
Feb 26, 2011 04:26 AM
