clutch.............
Old Sep 25, 2002 | 08:24 PM
92CIVICCX's Avatar
Default clutch.............
got clutch replaced.... then shop says ohh your slave cylinder is bad.. before igot my clutch replaced.. my clutch pedal had decent pressure on.. i just got it back and the clutch pedal has very weak pressure to it.. they say its because of my slave cylinder.. any ideas??????
Old Sep 25, 2002 | 09:09 PM
kinesistech's Avatar
Default Re: clutch............. (92CIVICCX)
Try bleeding before replacing anything. Its the same as bleeding brakes.
Old Sep 25, 2002 | 09:16 PM
Kamin's Avatar
Default Re: clutch............. (kinesistech)
yea im willing to bet money the shop fucked up.
Old Sep 26, 2002 | 12:41 AM
Quik Chris's Avatar
Default Re: clutch............. (KAMiN)
Did you notice the slave was leaking down the front of the tranny/onto the driveway when you took the car in? If not, it's fine.
I think they fucked it up too, that's wack.
Old Sep 26, 2002 | 05:16 AM
John's Avatar
New User
What kind of clutch did you install? If the new clutch has a stiff pressure plate, then it's quite likely you've blown your clutch master or slave cylinder. But first, look for brake fluid leakage around the slave cylinder (on your tranny), and then on your clutch master cylinder (look behind your pedals too).
Ek9b20v
12
Mar 31, 2013 01:21 PM
typerekb16
Dec 19, 2006 08:43 AM
Surestick
Aug 23, 2006 10:56 AM
mc
Mar 16, 2004 06:49 AM
SlowPoke
Nov 25, 2002 09:36 AM
