Acura NSX Honda / Acura NSX 1990 - 2005 || Honda / Acura NSX 2017 -
leg and head room in a nsx??
Old Feb 24, 2011 | 01:26 PM
hatchieg's Avatar
Default leg and head room in a nsx??
im 6'3 thinking about a nsx in the future just wonding if ill even fit before i start looking for one. Anyone have any info thanks..
Old Mar 20, 2011 | 09:18 AM
HondaSurgeon's Avatar
Default Re: leg and head room in a nsx??
You can definitely fit in there no problem. Remeber, when you are seated in a NSX, the seats sit right on the floor. So to comfortably sit, you have to adjust the seat so that you are almost reclined. I know it sounds weird explaining it, but even if you are short, you cant sit straight up like in your normal car. You just have to sit in one to see what Im talking about, but the main idea is... Yes, you will fit no problem.
Old Mar 30, 2011 | 05:34 PM
Meeyatch1's Avatar
I have found that at 6 feet tall there are a few options:
1.) Sit with the OEM seat reclined quite a bit.
2.) Get a modified OEM seat cushion that lowers your seating position.
3.) Aftermarket seats. When I had Bride GIAS seats in mine it let me have PLENTY of room.
Old Mar 30, 2011 | 05:41 PM
jlsnyderTypeR's Avatar
Another suggestion would be to look for a coupe. It doesn't have the beam across the back which gives you a little more head room.
I'm 5'8" so mine was made for me!
Old Apr 10, 2011 | 10:18 PM
hatchieg's Avatar
thanks for all the info!!
Old May 19, 2011 | 08:39 AM
DChan415's Avatar
You really need to sit in one yourself to know.
Old Jun 20, 2011 | 02:40 PM
NSXTCY's Avatar
You'll fit fine. It really helps with the telescopic steering wheel, the NSX has. If you can fit in an S2k, you will definitely fit well in an NSX.
Old Jul 7, 2011 | 03:49 PM
bluensx's Avatar
Leg room on drivers side will be no problem. The passengers side is quite a bit less-warning for whoever will be sitting there. Perfect for my 5' 4" wife.
eeebrahim
Honda CR-V & Element
Dec 5, 2021 06:57 PM
IncaEM2
Honda Civic (2001 - 2005)
Jan 20, 2008 02:44 PM
JDMlyfestyle
Mar 11, 2004 02:52 PM
Racebrewer
Mar 26, 2002 12:51 PM
