Oil Leak/Gasket Kit
Old Feb 24, 2011 | 09:02 AM
Dontoh's Avatar
Default Oil Leak/Gasket Kit
Ive got oil in my spark plugs, and leaking out of (which seems to be) my cam gears.. I was looking to get a gasket kit and hope it solves the problem. I just have no idea what to look for, should I go OEM or aftermarket? Also, does anyone have any idea why it might be leaking? if it's something simple, then I'll skip buying the entire kit and just get what I need
Old Feb 24, 2011 | 09:25 AM
night's Avatar
Default Re: Oil Leak/Gasket Kit
spark plug tube seals if DOHC, or rocker arm assembly orings.
and then cam seals. cam seals is doing a tbelt.
Old Feb 25, 2011 | 01:40 PM
Dontoh's Avatar
so spark plug tube seals, rocker arm o rings and cam seals to be safe? why would i have to do a tbelt?
Old Feb 25, 2011 | 01:51 PM
night's Avatar
if cams seals haven't been done then it is unlikely the crank seal and water pump have
Old Feb 25, 2011 | 01:57 PM
Dontoh's Avatar
true, thats the problem i'm having. the motor was rebuilt before i bought it, but i cannot contact the previous owner about what was actually done. i don't want to guess and have things fail, but i also dont want to waste a bunch of money on replacing parts that only have 4k on them
Civichatch972
30
Feb 6, 2009 11:47 AM
itzyaboyzeem03
Nov 2, 2008 01:47 AM
itr1235
May 28, 2007 03:54 AM
sinister357
Aug 29, 2005 09:47 PM
mickey513
Aug 8, 2004 06:39 PM
