Swapping factory clusters?
I hate that the base model ef with the d15b1 dp motor doesnt have a tach, is there a way to put in a si cluster or just a ef cluster that has a tach? If i can, where do i pull the signal for the tach? I searched the forum but can't find anything.
hey you just need to get an ex or an si cluster from an ef. 88-89 are the same 90-91 are the same so if you have a 89 civic you need to either get an 88 or 89 cluster with a tach. And you wont need to run any wires its just plug and play. contact me if you need one I have a few.
biggreen96
Apr 8, 2013 08:32 AM
civicminded93
Jan 5, 2012 09:48 AM
