ep3 with buddy club RSD coilover....
Old Feb 24, 2011 | 06:32 AM
udontknowjack's Avatar
Default ep3 with buddy club RSD coilover....
whats the max camber you can get with their camber plate? i search and read someone way back can only get -2 camber? that would be disappoint if its truth....
Old Feb 25, 2011 | 12:16 PM
josh's ep3's Avatar
Function > Form
Default Re: ep3 with buddy club RSD coilover....
Sounds about average to me. The problem with our car's suspension is getting good suspension geometry. How much camber do you plan to run and what for? I'm pretty sure the only way to max out the camber in the front is with the camber plates maxed and getting some crash bolts as well.
Old Feb 26, 2011 | 06:43 PM
man...if only -2 sounds about right then thats a joke....i got -2.2 with eibach spring/tokico shock and 1 camber bolt....
i need at least -3 to -3.2.... only time i drive my ep is to and back from autox event....
Old Feb 28, 2011 | 11:25 AM
mustclime's Avatar
just add a camber bolt to each side and tq the heck out of the lower bolts...............
Old Feb 28, 2011 | 08:40 PM
i will...already had them on the old set up...
still cant decide if i want to man up and fender flares the ep and throw some 275 to combat the DC2 and light weight EG in my region's smf class....
Old Feb 28, 2011 | 09:24 PM
josh's ep3's Avatar
Function > Form
DO EEt! I was contemplating flares for ever and never did go through with it. It's easy to tell someone else to though xD There are also the ChargeSpeed fenders as an option, but I def. don't think they would fit 275's.
Old Mar 5, 2011 | 04:26 PM
got alignment today
front
camber
-3 left -3 right
caster
1.7 left 2.2 right
toe
-0.07 left -0.06 right
total toe
-0.12
rear
camber
-1.8 left -1.7 right
toe
o
Old Mar 6, 2011 | 02:48 PM
http://vimeo.com/20719413
got much to learn and work on how to drive smooth....= (
Old Mar 9, 2011 | 12:47 AM
Pitbull Engineering's Avatar
Originally Posted by udontknowjack
got alignment today
front
camber
-3 left -3 right
caster
1.7 left 2.2 right
toe
total toe
-0.12
rear
camber
toe
o
IMO you should do smth with your caster. The difference is too big
Old Mar 9, 2011 | 06:11 AM
Mr. Spade's Avatar
looks good, but yea why is caster so low on left?
and I hope your camber bolts were impacted.
JustOneOrTwoPosts
Honda Civic (2006 - 2015)
Jul 15, 2012 09:42 AM
James89DX
11
Jun 8, 2009 11:26 AM
mikeycivic
Suspension & Brakes
Mar 31, 2008 04:00 PM
$amGD3
Suspension & Brakes
11
Sep 5, 2005 05:16 PM
