What are these parts on this sir1???
Old Feb 23, 2011 | 09:44 AM
JDMAF's Avatar
Default What are these parts on this sir1???
So I decided to see if my luck would be any better over here due to you guys having more experiance with this motor...
Ok so I figured out that the motor that came with my car is acually a SIR 1 b16a...
I was origanally told it was an SIR2 obd1 motor...
It has been converted to obd1 at least...
It had also been tore apart ie... intake off, exhaust off. you get the idea. Picked the car up with the motor on a stand.
car came with a Skunk2 intake manifold, and I started to move things over and realized that there are a couple parts im unfamiler with and how to hook them up or if they are even needed...
this is the best pic I could come up with using google...
What are they and what do they do???
oh and what the hell is this thing???
Old Feb 24, 2011 | 06:46 AM
dephtone's Avatar
Default Re: What are these parts on this sir1???
The top picture makes me think that is emissions stuff.
The 2nd picture is the Fast Idle Control valve. This is the common culprit if the car has a the sparatic idle. Where it bounces up and down from 500-1000 rpm idle.
Old Feb 24, 2011 | 07:10 AM
Getownit's Avatar
havent known an older honda that hasnt had a idle problem.
Old Feb 24, 2011 | 07:56 AM
kid-honda's Avatar
Top stuff can be removed with no issues and as stated bottom is fast idle valve which can also be removed if wanted.
Old Feb 24, 2011 | 11:37 AM
JDMAF's Avatar
If I do get rid of the fast idle valve will the obd1 throw a code???
Old Feb 24, 2011 | 02:49 PM
4drEF's Avatar
Keyboard Humorist
Basic purpose for that Air Boost Valve is to help keep your RPM from falling quickly between shifts. It's not necessary to have them as all the newer B motors got rid of them.
JDMAF
Feb 23, 2011 09:33 AM
KDvtec5757
May 12, 2009 11:54 PM
Chewy Built !
Jun 20, 2008 12:52 PM
Justin91CRXSi
Feb 25, 2007 09:38 PM
