Rbwdriven - ef parts Hatch, sedan and crx.
Contact Info: pm
Need money for my wagon. I'm also parting out a 1989 civic si for my other build. might have the parts you need let me know.
CRX hatch shocks - $20
CRX dx center tail light garnish $30
side dash mounts both $10 (3 sets)
CRX dx under hood fuse box - $20
CRX dx ignition harness - $25
CRX dx tail light harness - $25 both
CRX wiper linkage - $30 (2 sets)
Steering shaft cover (3) - $5
CRX door hinges - $30
dash vent piping on driver side - $15 (2 sets)
CRX wiper motor - $20 (2)
CRX cowl panel - $30 pick up only (possibly have a sedan one and also a hatch) I know I have 3 or 4 of them.
88-91 civic pm5 ecu -$10
88-91 hatch lower console with light blue - $10
88-91 suede door panels – manual windows - $250 (door panels might not be for sale )
90-91 crx outer passenger door handle w/o key - $10
90-91 crx door handle inner - $5
90-91 crx passenger window regulator - $15
90-91 crx passenger door wiring - $10
88-91 resistor box - $10 (2)
90-91 sedan rear power window switches and handles (blue) - $10
88-91 crx gas door (2) (white & Black) - $5
Bumper plate lights - $5
CRX hood release cable - $15
CRX fuel release cable - $10
Trunk/ fuel release mount - $5
90/91 CRX driver side corner light - $5
CRX rear interior trim panel - $15
90/91 CRX door catch strap - $5
sedan power window switch - $10
std steering wheel (2) - $10
Sedan door handles - $10
90-91 headlight and corner lights - $60
sedan door lock relay - $5
door mounted belts - $10
90-91 door harness - $10
88-91 hatch console si with light black - $20
blower motor assy (2)- $15
sedan auto belt relay - $5
ac harness (2 sets) $10
Rear speaker/ pockets $30
Blower motor - $10
Under Hood fuse box with cover - $25
1989 civic si part out – as of end of feb
http://eastcoastefcivics.com/index.php?topic=2621.0
more stuff as of 2/5/2011
civic ¼ panel plastic (both sides) - $30
90/91 civic sedan door moulding - $40
crx center console - $20
Sun visors - $10
Sedan rear mud flaps (now clean) - $20
Hatch front mud flaps (now clean) - $20
90/91 steering column trim - $10
88/89 steering column trim - $10
Prop Valve 35/40 - $15
Prop Valve 17/25 (2) - $15
Fuel door/ Trunk release assembly - $15
88/89 passenger door panel blue - $15
Civic dx hatch. - $20
Dash end pieces - $5
Contact Info: pm
Blower motor - $10
Sun visors - $10
Did you remove the CRX wiper linkage yourself? A shop removed mine and now I don't know how to reinstall another set like yours. There is nothing in the FSM, and the Parts Manual blowup picture is not accurate for installing.
There are 2 rotating 'posts' (with triangular bases, held on by 3 screws) to which the wiper arms attach. Can you tell me which way the very short arms that are on each of these 'posts' face - both down, both up, or 1 of each? I don't think you have tried to lay them out in your picture as they are installed.
I also had a problem with those 2 w/w posts not clearing the hood when I tried to close it. They were hitting the underside of the rear edge of the hood. The triangular bases can attach only 1 way, so I don't see how I could have them out of position.
If you could help me with this it would be very appreciated. It would allow me to buy yours and actually be able to get them installed! Finding a '91 CRX in a wrecking yard around here to take a look at it has been impossible.
Jim in NY
Jim in NY
Jim,
Yep removed them myself and also installed them into other cars myself.
you need to make sure you thread the one with the little rectangular bar towards wiper motor.
I usually do it the easy way.
turn on ignition so that it is on. turn wiper motor on then let it rotate. Turn off.
Attach rectangular bar. need to make sure that you middle one located then the driver side located.
If you do not do this, the wipers driver side or passenger side with rotate backwards.
then attach rectangular bar to motor.
Test and that should be it.
shortA25
Dec 13, 2012 07:27 PM
shortA25
Mid-Atlantic (Sales)
Dec 13, 2012 07:26 PM
crxman00
Mar 14, 2003 06:43 AM
