DB RS -- only trim without sunroof?
I spent some time today searching for an 00-01 Integra sedan without a sunroof, only to find out that they dropped the RS trim level in 98. Could you get an LS without a sunroof after that, or did Acura just put a sunroof in everything that didn't have an R badge?
I'm pretty sure most sedans had a sunroof. You'll be hard-pressed to find a sedan without one, methinks, if they even exist.
Last year they made a DB7/8 RS (w/out Sunroof) was '96. All of the other trims had sunroofs. (Per KBB, hopefully thats correct!)
RS trim in a 4-door is difficult to find. :-/
Not as bad as you would think...they're really easy to find cheap, but they're typically in $hit condition.
Its the clean DB's that create work!
DB7 RS is the trim you'll be searching for.... 94-96. No Moonroof FTW!
GL.
DB7 RS is the trim you'll be searching for.... 94-96. No Moonroof FTW!GL.
jfruauff
Jan 2, 2007 03:23 PM
