Integra always stalling and low idle
I got a 95 integra. It has crower 404s . Is the morning when I start the car the car won't stall idling until the temp guage get to about 1/4. The whole time until it get there the car feels and sounds like it has a rod knock or it's misfiring ?? Which is weird . After the 1/4 car idles smooth right around 1100 were I have it set I'll start driving it no problem then as soon as it hit normal running temp the car stall right out or idles around 50-150 then stalls . When the car stalls I pop start it then it idles around 1100-1300 and sounds like I have a huge vacuum leak . Then it wears out after a couple of minutes and I have to go through the same step .. Car runs super rich (10s) on the wideband when it's about to stall or low idle . ?? Need help thanks in advance
sounds like a problem with the tune
wut program are u using?
it also could be a vaccum leak once one thing goes wrong on any tuned ecu they tend to go crazy
BigDaddyRich
Jan 11, 2012 08:11 AM
KillerElfboy
Apr 12, 2008 10:42 AM
