Suspension Help!!!!!!!!!!!!
I want to get a coilover set up for my ek hatch looking to spend a g or less so far i'm looking into
-buddy clun n+ spec
-ground control w/ koni yellows
-skunk 2 pro
anyone with any input from experience or any other suggestion is really appreciated, also i dont want the ride to suck completely lol.....thankz
-buddy clun n+ spec
-skunk 2 pro
What are your needs/wants/goals for the car? That will determine what spring rates are best for you. Regardless of spring rate, I always recommend Koni/GC as it's a superb setup for around 800 bucks.
There are a lot of "which suspension to buy" threads and they typically converge on Koni/GC like PatrickGSR94 said. I was in the same situation as you with a similar budget and went with Koni/GC with extended tophats all around and really like the ride. It's my first suspension set-up so I can't compare with the others but I don't have any regrets.
thanks for the response pat, the car is my daily driver, but I autox on the weekends. I also want the car to be kind of slammed, as low as i can go wit these shi**y roads in NJ haha
and GL
Mine is a daily driver / ST class auto-x / HPDE 2000 Integra GSR, Koni w/ GC 400/400 lbs/in rates. Acceptable for auto-x, but not quite stiff enough. 600/550 rates sitting on a shelf waiting for install, but that will be very stiff for daily use.
-buddy clun n+ spec
-tein basic
-d2
-skunk 2 pro
-buddy clun n+ spec
-tein basic
-d2
-skunk 2 pro
but what everyone else here said is true, what are you looking to do...autox/drag/dd/street. im looking for the best combo for my suspension set up. (i wanna have poly bushings so i dont want suspension thats gonna make it too stiff)
Do a bit of searching and see what many people have experienced as far as those go before you decide to spend the money.
And poly vs. rubber really only changes the high frequency NVH. The stiffness of the suspension won't change with either material, assuming both are in good condition.
top hats not really needed
extra 60 bux gets a better setup, but its your car do what u want
not to mention lifetime warranty on konis shocks
yea but i'm not s sure that the ground controls are better setup i been reading up on the junior specs and from what ive read they're the sh*t so i think i'm gonna go with them
Also not sure where you're finding the $740 price. Everything I see on the web has them around $1500.
civexspeedy
10
Mar 26, 2008 07:37 PM
