Transmission & Drivetrain Gearboxes, Differentials, Clutches
si gears in ls trany?
Old Feb 21, 2011 | 05:08 PM
mhewitt's Avatar
Default si gears in ls trany?
well i took my ls tranny and pulled all the gears off of both shafts and replaced them with a full set of si gears trying to make it more like a gsr tranny. my problem is that now the case wont go down becuse the top bearing on input shaft is not lining up te si gears r pushin the shafts apart to thpoint where they arent quite straight from top to bottom. anyone tried this before and have any solutions?
Old Feb 21, 2011 | 05:25 PM
94EG8's Avatar
Seagull Management
Default Re: si gears in ls trany?
You can't use a full set of Si gears. You have to keep the LS 1st and 2nd due to the fact that those gears are part of the input shaft on the input shaft side of things.
Old Feb 21, 2011 | 05:33 PM
mhewitt's Avatar
i kept the ls shafts to match up with my ls diff, i meant that i swapped all of the other si gears onto the ls shafts
Old Feb 21, 2011 | 05:57 PM
94EG8's Avatar
Seagull Management
Did you or did you not use the B16 1st and 2nd gears on the countershaft?
Old Feb 21, 2011 | 06:08 PM
Aquafina's Avatar
If you're using the LS mainshaft you have to use the LS countershaft 1/2 gears. B16 mainshaft you have to use B16 countershaft 1/2 gears. B16 mainshaft you will need to shim.
Old Feb 21, 2011 | 07:36 PM
mhewitt's Avatar
ok, i took everything off of an si mainshaft that would come off and slid it all onto the ls mainshaft. i did the same thing on the countershaft, pulled everything off of the si shaft that would come off and tapped it all back down on the ls countershaft n put those stacks in the tranny with the ls diff n ring gear. using the si shift forks because they ere a lil different than the ls ones
Old Feb 21, 2011 | 07:37 PM
mhewitt's Avatar
by "shimming" do you mean the 2 washers that go under the mainshaft when putting it in the tranny?
Old Feb 21, 2011 | 07:48 PM
mhewitt's Avatar
im going to use the ls main and countershaft, so i need to put the ls 1-2 gears back on but leave the rest of the si gears on here, right? 1-2 gears are starting from the bottom and counting up on the gears that are removeable, correct? there s a final drive gear that is made to the countershaft, then reverse gear also made to shaft, then first followed by second?
Old Feb 22, 2011 | 03:58 AM
94EG8's Avatar
Seagull Management
Right
Not exactly. Final drive gear, then 1st, then 2nd. Reverse is part of the 1st/2nd sleeve on the countershaft side. It's cast into the mainshaft between 1st and 2nd on the mainshaft side.
Old Feb 22, 2011 | 05:11 AM
mhewitt's Avatar
ok, yeah i knew that. was late when i typed that post lol. thanks or the help guys ill c how it works out
DaFredsta
Nov 16, 2011 07:02 AM
mhewitt
Apr 17, 2010 01:13 PM
vegassinsation
Apr 10, 2008 10:57 AM
chRisDc5
Nov 17, 2004 11:45 AM
