Low RPM Hesitation under 3k when warm
Hey HT, im havin a problem wit my car that recently developed...
When my car is cold, it runs STRONG, no problems at all.
BUT, once its warmed up, it runs like **** under 3k, and once it hits 3k, it runs amazing like it should. But along wit that, the idle is very low and missing. and a lil hard to start. im clueless.
Things i replaced are:
-ECT sensor
-TPS sensor
-Cap, rotor, plugs and wires
-Cleaned the iacv
Thats all that i can think of..
Any thoughts of what it can be??
Keep in mind that its ONLY happening when warmed up.
Thanks!!
P.S.
Just for reference, its a 95 civic wit a b18b1
-ECT sensor
-TPS sensor
-Cleaned the iacv
Thanks!!
P.S.
i think its your o2 sensor what you should try is unplug your o2 sensor start
your car let it warm up and if nothing happens then its your o2 cause this happened
to me with my eg did the samething when warmed up
Oh im running without an 02 sensor. My ecu is chipped so it disables it. thanks for the reply tho!
check your timing take a timing light to it may be off just a little or may need to be tightened its weird my DA9 does that with a b20 and im getting my timing redone on friday but id look for that
mark_is_gay
Mar 24, 2007 01:00 PM
5lugcivic
Apr 7, 2005 10:25 PM
