F/S '92 - '00 Civic parts.
Old Feb 21, 2011 | 10:52 AM
94EG8's Avatar
Seagull Management
Default F/S '92 - '00 Civic parts.
This is my i'm going to school and I need money, for sale thread. More parts coming soon. Located in Atlantic Canada, shipping for all parts at buyer's expense.
P07 VX ECU Canadian market, same as US federal, $60.
'96 - '98 5 speed dash harness, was pulled from a '98 DX hatchback $40
'92 - '95 Civic Grey non-SRS steering wheel, has some discoloration and wear $20
'92 - '95 Coupe/Sedan OEM tailights, scratched a bit, could be buffed out, also they were etched with a serial number in case of theft. $50 for the set (have a couple of other sets as well)
'93 - '95 Coupe Gas door $10
'96 - '00 Civic Automatic rear T-bracket $20
'96 - '00 Civic Automatic upper transmission bracket $10
'92 - '95 Automatic rear mount $10
Heatshield for a '96 - '00 Civic (I think, it's been a while since I got this) $10
'92 - '95 Civic A/C delete duct work $15
'92 - '95 Civic (may also fit '96 - '00)A/C condensor block off plate, have 2, $5 each
'92 - '95 Civic underdash fuse panel, came from a '95 Canadain Si Coupe with dual airbags $20
'92 - '95 Civic OEM cruise control computer $10
'92 - '95 Civic Dash switches, $5 each or $10 for all 3
'92 - '95 Civic 7/8 brake master cylinder, bolts to OEM non ABS Civic brake booster, pulled from a '93 Canadian Si coupe, Original Nissin, not remaned $40 Edit, found another one of these i'd forgotten I had, it's in worse shape cosmetically, but works fine and is also an original honda part.
'92 - '95 Civic starter for automatic $30
'92 - '95 Civic crank pulley without P/S pulley, no bolt or key $10
'92 - '95 Civic crank pully with P/S pulley, have a few, no bolt or key, $10 each.
'92 - '95 Civic rear T-bracket, fits both automatic and 5 speed - $20
'92 - '95 Civic wiper transmission/motor, have 2 $20 each
'92 - '95 Civic CX/VX intake arm $10
Added new parts March 21st
'99 - '00 Climate Control parts, untested $30
'94 - '01 Integra passenger's side door harness, speaker plug cut, came from a '97 Anniversary edition $10
13" Honda hubcaps, standard equipment on '92 - '95 Sedans with 13" wheels, requires lug nuts with plastic ring. Used with some wear $30 for the set
New parts June 4th/11
D15Z1 P07 VX pistons and rods 420,000kms on them when removed, did not have any spun bearings and the pistons are actually in pretty good shape, will need new rings though. Rods Sold, Pistons still for sale $20 OBO
D15Z1 VX Crank. 420,000Kms on it, no spun bearings, no scoring etc. $50 OBO
OBD2A P2P (D16Y8) ECU: 5 speed. Canadian ECU, same as US federal except it doesn't look for and wont throw a CEL for an ELD. Fits '96 - '98 Civics. $50
D16Y8 throttle body Fits 5 speed D16Y8s only Will not work on automatic models!!! MAP and TPS sensors are good. $30
D16Y7/D16Y8 Automatic 3 wire rotary style IACV. Cleaned up and not sticky, Fits '96 - '00 Civics with a D16Y7 or an automatic D16Y8. Green motor part also fits '95.5 - '00 Toyota Tacomas with 3RZ-FE (2.7L) May fit '01 - '04 as well, not sure.
Honda OEM throttle body mounted MAP sensor. Fits most D/B/F/H-series engines with throttle body mounted MAP sensor.
OBD2 injector clips with plastic for a D16Y8. $10
Old Feb 23, 2011 | 08:46 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: F/S '92 - '00 Civic parts.
TTT
Old Feb 26, 2011 | 04:19 AM
94EG8's Avatar
Seagull Management
Bump
Old Feb 26, 2011 | 06:14 AM
sk8shorty012's Avatar
bump!
Old Mar 7, 2011 | 07:19 AM
94EG8's Avatar
Seagull Management
Bump, need money for school!
Old Mar 7, 2011 | 07:35 AM
fallbacdun's Avatar
'97 Integra dash harness, cut but the plugs could be used for putting an integra cluster in a Civic $5
ill take this bro how much for shipping to 32714
Old Mar 12, 2011 | 11:04 AM
tlarimer's Avatar
Condensor block off plate shipped to thayne, wy 83127? Does it come with clips?
Tim
Old Mar 21, 2011 | 02:29 PM
94EG8's Avatar
Seagull Management
Bump for new parts.
Old Mar 22, 2011 | 11:20 AM
kwilson25's Avatar
i need a crank pulley for a d16z6 can ya help? thanx
Old Mar 22, 2011 | 11:53 AM
94EG8's Avatar
Seagull Management
I've got one from a Y7, pretty sure it will work, I've got my Z6 half apart right now so i'll check tonight and see if it fits. It does $10 plus shipping, it's got a minor chip on the back side but it shouldn't cause any problems.
Old Mar 24, 2011 | 07:53 AM
94EG8's Avatar
Seagull Management
Bump
Old Mar 28, 2011 | 04:58 AM
94EG8's Avatar
Seagull Management
Bump.
Old Mar 29, 2011 | 11:38 AM
hmoobhero's Avatar
received the cluster. thanks man!
Old Mar 30, 2011 | 08:56 AM
94EG8's Avatar
Seagull Management
bump, still got lots of stuff left, will be adding more stuff soon.
Old Apr 3, 2011 | 04:41 AM
94EG8's Avatar
Seagull Management
Bump.
Old Apr 4, 2011 | 04:34 PM
Randolph's Avatar
How much to ship the upper 5 speed manual bracket to new york? Thanks
Old Apr 4, 2011 | 04:44 PM
94EG8's Avatar
Seagull Management
I'll get you a quote tommorrow and send you a PM.
Old Apr 4, 2011 | 06:29 PM
Randolph's Avatar
Ok. I need the one with the lug nut, if not no biggie. PM me please, thanks.
Old Apr 8, 2011 | 02:01 PM
Buddha.z's Avatar
PM'd
Old Apr 18, 2011 | 09:19 AM
94EG8's Avatar
Seagull Management
Bump
Old Apr 18, 2011 | 11:32 AM
CRXFREEK9000's Avatar
i need the ex/si engine and dash harness if still available need shipping quote to 70364
Old Apr 18, 2011 | 01:20 PM
94EG8's Avatar
Seagull Management
I'll get you a quote tommorrow.
Old Apr 18, 2011 | 05:31 PM
thanks
Old Apr 21, 2011 | 04:20 AM
94EG8's Avatar
Seagull Management
thanks
Crap! I totally forgot to go to the post office, I'll get you a quote today. I also didn't realize you were looking for the engine harness too, it's sold locally. Dash harness still available. If you have a DX engine harness to use for a core and you want a harness built PM me and I might be able to work something out.
Old Apr 28, 2011 | 09:55 AM
94EG8's Avatar
Seagull Management
Bump, added more stuff.
