to those with 90-91 CRX SI rear discs and stainless lines--where did you get them??
Old Sep 25, 2002 | 05:56 PM
spettinger's Avatar
Default to those with 90-91 CRX SI rear discs and stainless lines--where did you get them??
i just broke my fitting on my stock 89 CRX SI rear drum, trying to bleed the brakes. looks like my rear disc swap is happening right now. need to know where to order the lines, and do they differ at all from the integra, as i have integra arms. thanks!
Old Sep 25, 2002 | 06:11 PM
Francois's Avatar
Default Re: to those with 90-91 CRX SI rear discs and stainless lines--where did you get them?? (wreckedhatc
All Honda that have rear disk(Teg G2 and DC3(Except ITR),Delsol,Civic Hatch92-93 and Si99-00,Crx Si 90-91)have the same arm.(CND models...)
So that's why people are swapping them on there car...
Stainless line should be available at your speed shop near you.Unless,pep boys carry them
[Modified by Francois, 10:12 PM 9/25/2002]
Old Sep 25, 2002 | 06:33 PM
civbeater90's Avatar
i got a set of stailnless lines for 79.00 from summit.they are made by russell in conjuction with edelbrock.
Old Sep 25, 2002 | 07:05 PM
spettinger's Avatar
$80 for all four?? lightning sells the 4 piece for $118 shipped, i have integra front hubs so i want to get the integra lines...that way the fitting on the brake is not stressed to reach the vertical arm.
are the front fittings all the same between CRX SI's and 90-93 tegs?? thanks.
Old Sep 25, 2002 | 07:09 PM
philly-O's Avatar
optauto.com the set of 4 is $91 plus shipping. they are jg edelbrock made by russel
Old Sep 25, 2002 | 07:12 PM
spettinger's Avatar
cool. do the integra ones have any different fittings to the hard lines? i put on my integra fronts and it would be nice to run the proper lines as the spacing between the caliper and a mounting point changes.
my guess is the kits have the same ends with different lengths and mounting points.
Old Sep 25, 2002 | 07:34 PM
philly-O's Avatar
just use the crx lines for the front/rear disc setup. the only thing you will have to buy because you are using integra discs on the rear in new e-brake cables. they are too long to use on a crx or civic.
Old Sep 25, 2002 | 09:22 PM
spettinger's Avatar
i was going to buy crx ebrake cables....you say i need integras? explain. thanks.
Old Sep 25, 2002 | 09:26 PM
robA90CRXsi's Avatar
they were thier when I bought the car(drum brakes suck!!!!)
and she looks better
1 2 3
Old Sep 26, 2002 | 03:22 AM
Jeff C's Avatar
yes
the teggy cables are too long.
you can make them work but it takes some riggin up.
Old Sep 26, 2002 | 05:15 AM
Doodoo's Avatar
I second that. I used 90-91 ebrake cables for my 88 Si. Perfect fit.
[Modified by Doodoo, 8:15 AM 9/26/2002]
Old Sep 26, 2002 | 08:18 AM
Steve91's Avatar
I have Neuspeed brake lines. They work great.
jaje
Aug 5, 2009 02:59 AM
teler86
10
Dec 3, 2006 04:20 AM
crxhftosi
Jan 30, 2005 10:13 PM
alexdog69
Apr 15, 2004 03:28 PM
FourthGenHatch
Aug 31, 2002 07:07 PM
