timing belt issue
Old Feb 20, 2011 | 05:14 PM
93egboosted's Avatar
Default timing belt issue
im having a problem lineing up the timing on my ls vtec, the cams are lined up perfectly but the crank seems to be a bit off... this isnt my first big rodeo either lol, ive done plenty of others d and b series.
setup ls block
b16 head
gsr water pump
gsr timing belt
i had the block resurfaced before assembly, i dont kno for sure if the head was or how many times it was, maybe thats my issue?
heres a pic to show you what im dealing with
Default Re: timing belt issue
thanks in advance
john
Old Feb 20, 2011 | 06:27 PM
night's Avatar
that at the crank is very very little at the cams.
you should have some adjustable gears to account for the milling. search for the degrees per 10 thousands to adjust.
Old Feb 20, 2011 | 07:26 PM
search for the degrees? care to explain a little more? are you saying i have to put a degree wheel on my engine? ive seen them before but never used one
thanks
john
Old Feb 20, 2011 | 10:32 PM
mouab18c1's Avatar
Redo it. I had a b20vtec before and had no issue with lining up TDC marks.
Old Feb 20, 2011 | 11:15 PM
h2.4's Avatar
get adjustable cam gears, that is what they are for. If you've decked the block and don't know about the head, Then your crank, cam relation will be off.
Old Feb 21, 2011 | 08:17 AM
i did several times
Old Feb 21, 2011 | 12:16 PM
will i be able to adjust the crank to tdc with the adjustable gears without having to put a degree wheel on my engine?
thanks
john
Old Feb 21, 2011 | 07:22 PM
bump
Old Feb 21, 2011 | 07:43 PM
mouab18c1's Avatar
Adjustable cam gears are not going to make a difference. They all still have TDC marks which you will have to install the same way as stock cam gears.
Old Feb 21, 2011 | 07:51 PM
night's Avatar
The rule of thumb is, and it's been covered a few times, is for every .040" thou (1mm) removed, you advance your cam gears 1 CAM degree (this translates to 2 crank degrees for ignition timing correction). So if you remove .030" from the head and then use a 2 layer headgasket, it equals .040" total. Same goes for decking etc, you just add up the total amount removed and go from there. If you only remove .020" total, it is corrected by 1/2 a cam degree.
Old Feb 21, 2011 | 07:56 PM
mouab18c1's Avatar
Hmm from what I heard cam gear adjustments are only needed for cam degreeing/adjustments on a dyno.
Old Feb 22, 2011 | 05:01 AM
kyden's Avatar
and when there's a good amount milled off the block/head.
Old Feb 22, 2011 | 07:54 AM
mouab18c1's Avatar
You learn something new everyday!
Old Feb 22, 2011 | 03:54 PM
i really dont know how much the head has been milled. instead of running a thinner headgasket could i degree the cams more than what you are saying i have a golden eagle three layer. if so to do this correctly i would have to use a degree wheel?
thanks
john
Old Feb 22, 2011 | 04:08 PM
night's Avatar
a degree wheel has nothing to do with this. if the block was milled and the head has ever been off before this time, it is a safe bet to assume 20 thou off. so set the 1/2 degree on the cams and see where that puts you.
if the machine shop had the head this time when they had your block, it is a very safe assumption they did. if it was just some general shop that doesn't think in terms of Honda it is standard procedure to cut the head. the only way to check it is to go to northern tools or harbor freight and grab a cheap caliper. measure the thickness of the head.
Old Feb 23, 2011 | 01:51 PM
im gonna pick up a set of cam gears this week, and im gonna adjust them and see where that brings me, before i pull the head off and measure it...
Old Feb 23, 2011 | 02:54 PM
Honda Bull's Avatar
Show us a photo of where the crank cog (not the crank pulley) lines up it's mark to the triangle mark on the oil pump.
Old Feb 23, 2011 | 08:20 PM
i did the best to square the crank up, left to right is pretty much prefect, up and down i did the best i could because the engine is in the car and the body got it the way
Old Feb 25, 2011 | 09:14 AM
bump
Old Feb 25, 2011 | 09:49 AM
dmfl666's Avatar
forsure get some adjustable cam gears
Old Feb 25, 2011 | 12:19 PM
yea i just ordered a set of golden eagles, i called my engine builder to see if he can put his degree wheel on my engine but im pretty sure i have to pull the engine back outa the car!!
Old Feb 26, 2011 | 04:02 PM
so engine is out waiting for the gears to come in
Old Mar 2, 2011 | 05:37 AM
Honda Bull's Avatar
Yup. Something was definitely taken down (block or head) enough to change where everything lines up. I just wanted you to verify that the mark you were seeing on the crank pulley wasn't just the outer portion of the pulley rotating on the dampening material, which is quite common. This is also why you should always time the engine with the crank cog and not the pulley.
paulzy
Engine Machining & Assembly
15
Jan 23, 2020 06:16 AM
IntegraMark
Sep 29, 2009 05:07 PM
Renegade
Feb 13, 2007 08:01 AM
gsr dood
Mar 23, 2006 10:21 PM
Power Rev Racing
Sep 8, 2005 12:16 PM
