how to re-chip JDM B16A EG6 ECU (OBD1 P30)
Old Feb 20, 2011 | 04:48 PM
znoj's Avatar
Default how to re-chip JDM B16A EG6 ECU (OBD1 P30)
Hi Guys,
need help how to re chip EG6 ECU obd1 P30, what do i have to do
I want to try this one since I have a spare ecu.hope you can help me
Old Feb 20, 2011 | 05:09 PM
94EG8's Avatar
Seagull Management
Default Re: how to re-chip JDM B16A EG6 ECU (OBD1 P30)
Thread moved to engine management and tuning. You should get better responses here. Actually what you want to know should be right in the FAQ at the top of the page.
Old Feb 20, 2011 | 05:21 PM
ReDHaTcHyGuy's Avatar
contact john kerr at JKtuning.com
Old Feb 20, 2011 | 09:50 PM
mouab18c1's Avatar
As long as you have soldering skills it should be simple.
http://www.angelfire.com/extreme3/dr...a_honda_92.htm
Old Feb 21, 2011 | 12:37 AM
znoj's Avatar
thanks so much mouab18c1 I appreciate it so much.. this is DIY time
and one more thing if my EG6 is orig JDM can I use USDM ECU p30, I have spare for both JDM and USDM which one should I use?
Old Feb 21, 2011 | 09:58 AM
mouab18c1's Avatar
If you're motor is a JDM then running the JDM ecu would make more sense.
Old Feb 21, 2011 | 11:00 AM
94EG8's Avatar
Seagull Management
The small case JDM ECUs use surface mount components are a bit harder to solder on, the long case are just as easy/hard as a USDM ECU. If you have a legit USDM OBD1 P30 i'd sell it someone in California as they need a matching USDM ECU for smog over there.
phoxking
Mar 25, 2011 12:04 PM
Jonovision
Aug 4, 2008 02:29 PM
Lou_EM1
Jun 9, 2008 07:12 PM
Full-Race Henry
Jun 4, 2004 07:55 AM
u2civic1
Apr 1, 2003 02:44 PM
