Could a Bad Ignition Switch Cause No Spark ?
Old Feb 20, 2011 | 02:41 PM
TheBigCheese's Avatar
Default Could a Bad Ignition Switch Cause No Spark ?
My 98 Accord has fuel but no spark. Turns over great but won't make any spark. The ignition switch has around 200k miles on it and looks worn out on the inside. Could a Bad Ignition Switch Cause No Spark ?
Old Feb 20, 2011 | 03:44 PM
phootbag's Avatar
Default Re: Could a Bad Ignition Switch Cause No Spark ?
Never seen it happen. I would suspect something else like a faulty ignition coil, broken timing belt, faulty sensor etc.
Old Feb 21, 2011 | 06:55 AM
uberEFtuner's Avatar
92 Accord Lx with 100,000
It can cause no spark. I know I,m an idiot, but I hooked up my battery backwards. Which I might have caused the lumps on contacts in my ignition switch. It would only run if I kept cranking the starter. I hot wired the car, which helped me diagnose the bad ignition.
Old Feb 21, 2011 | 07:00 AM
ME Motorsports's Avatar
There are three, main, items that will keep the engine from getting a spark. A bad ignition coil, a bad igniter and a bad distributor.
Old Feb 22, 2011 | 06:04 PM
craddock01's Avatar
And a bad ignition switch.Its easy to test with an Ohmmeter and a manual.
Old Feb 24, 2011 | 06:07 PM
Just a fuse. I should have figured. The ignition switch was looking pretty bad to start with though.
Old Feb 24, 2011 | 08:00 PM
nus_dogg's Avatar
So it was a blown fuse?
Old Feb 25, 2011 | 08:32 AM
Yup. I think my battery charger over charged the battery. Moral of the story is to spend money on a good battery charger.
Old Feb 25, 2011 | 11:16 AM
nus_dogg's Avatar
Gotcha.
Honda knowledge
Apr 18, 2015 08:00 PM
jacobsd1904
Feb 24, 2011 01:18 PM
twotonecivic
Apr 24, 2009 09:48 PM
rizzoTK
Aug 29, 2005 02:35 PM
