Suspension & Brakes Theory, alignment, spring rates....
BWR swaybar brace for an EG
Old Feb 20, 2011 | 02:38 PM
gutted-dx's Avatar
Default BWR swaybar brace for an EG
I bought this yesterday, and am kinda confused on how to install it. I tried to go off ASR's instructions but come to find out there totally different. BWR AL pieces go in front of the subframe instead of behind it. My question is do I need to buy nuts to fasten it to the back of the subframe, and was the kit supposed to come with? Any install pictures would help. I can't seem to find one with the Swaybar installed.
Thanks,
Joe
Old Feb 21, 2011 | 06:50 AM
gutted-dx's Avatar
Default Re: BWR swaybar brace for an EG
No one?
Old Feb 21, 2011 | 06:57 AM
phunhaus's Avatar
You should contact BWRSUPPORT. Send a PM here. He should be able to get back to you unless his laptop crashed again.
Old Feb 21, 2011 | 06:59 AM
gutted-dx's Avatar
I'll try that.
Old Feb 21, 2011 | 08:21 AM
PreyStayShun's Avatar
Classic thread, saw that.
Old Feb 21, 2011 | 01:26 PM
98civdx's Avatar
Master Detailer
Don't bother PM'ing him, he hasn't been on sence decmeber.
I guess those shock dyno's will never get posted?
Old Feb 21, 2011 | 06:07 PM
gutted-dx's Avatar
Yea I saw that, but I figured it out.
Old Feb 26, 2011 | 11:12 AM
STOCK_SOHC_DX's Avatar
So this frame brace only bolts in the front and nothing in between the actual subframe? I wouldn't install that thing unless you are trying to add weight or want a false sense of security.
Old Feb 26, 2011 | 11:46 AM
98civdx's Avatar
Master Detailer
If it's anything like the 96-00 there is a bracket that bolts to the subframe, and the brace bolts to that.
No backing plates either.
Old Feb 26, 2011 | 11:52 AM
In the title it states EG. I just installed the ASR brace on a friends DC so I'm assuming it's the same. without those plates I wouldn't run a bigger sway bar than 14mm.
Old Feb 26, 2011 | 12:52 PM
98civdx's Avatar
Master Detailer
I know it says EG.
I would assume his would be basicly the same on this EG, as it would be for EK.
Compared to ASR, while it is basicly a 1 piece part, for exception of the backing plates. BWR is just chunks of aluminum peiced togther with bolts.
Old Feb 26, 2011 | 02:36 PM
I know it says EG.
This thing doesn't brace anything.
Old Feb 26, 2011 | 03:55 PM
98civdx's Avatar
Master Detailer
Exactly what I was thinking. Noithing more then bling.
Old Feb 28, 2011 | 06:08 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
It's also a complete and total ripoff of Function7's subframe brace design. All BWR parts are F7 design ripoffs.
It's hard to beat quality construction like this.
http://www.function7.com/products/egbrace
Old Feb 28, 2011 | 06:36 AM
Libertariat's Avatar
Ek Forever y0!
Function7 is worth every penny.
It's on my list
BWR has had a reputation for inconsistent products that are just knockoffs of functional parts.
vietfella
Aug 20, 2007 03:51 PM
BlackMagikSI
19
Mar 19, 2007 08:19 PM
KMk51188
Apr 3, 2006 06:57 AM
MARDC5R
Feb 23, 2006 05:45 PM
