H23 - To boost or not to boost...
that is my question. I've got the motor and it needs rebuilding, which is why I got everything for $400cdn. So do I build for N/A or FI? If i go N/A i want the ****** to make power till 8000. If I go FI - DSM setup most likely, i want a reliable 12psi daily driver.
What do you guys thiunk?
i thought Nick M's reply was to ArchAngel Sabastian..?
i hope not. h22 has higher comp and better setup for an all motor app from the get go IMO. the .1 more disp the h23 has wont help that much i mean hell they de-stroke the h22 to h20 to make more power in some cases.
My reply wasnt directed to you Sabastian. It was directed to the first post. H23s vs F22s vs H22s have been a hot topic in here for months. Alot of our opinions can be found in old threads. Thats what I meant by research. H-T is a great place to do research.
err there was a post a while back about one version of a race/track accord with a h20 motor in it ( h20 stamped on the block as well ), honda didnt make it persay its just a destroked h22.
[Modified by ArchAngel Sabastian, 11:51 PM 9/25/2002]
to run 12 psi daily your looking at a $2000 build of the block. There is no question you WILL need that. You need to sleeve the block and put in forged pistons at the minimum. But with a good set of rods, you will have a much stronger block and you will leave future options open for more boost.
i did check through the archives and only saw the h23 vs f22 vs h22 stuff but no h23 FI vs H23 N/A.
we are gonna sleeve it either way so that's already in the game plan, it's got some bad rings.
[Modified by psyphre, 6:47 AM 9/26/2002]
I would boost.....takes soooooooo much more money to get an all motor even close to a boosted car.
All that money/work on an all motor car just to have me blow by them in a F22
in order to put different pistons in you must resleeve the block....if you use oem pistons with oem rings you can get away without it...in my opinion, just get some stronger rods, and some new oem h23 pistons...build the head adequately and run 10-12 psi on the street....(you will be able to get away with 15psi at the track as long as you don't do it every weekend)...that would be one monster of an engine by the way...
