Quick Offset Question??? 15"x6" wheel
Old Feb 20, 2011 | 09:12 AM
Turbo O's Avatar
Default Quick Offset Question??? 15"x6" wheel
Out of the following sizes, which would be a direct fit for any 88-00 Civic / 90-01 Integra?
* 15x6 35mm offset
* 15x6 40mm offset
* 15x6 45mm offset
Again these are the ONLY sizes I'm concerned about.
I sold a set of the 15x6 with 45 offset that were put onto a 1995 Civic EX and was told that spacers were need for the front, in order to clear the caliper. So I figure a lower offset should be fine, but would it be the 35mm or 40mm?
Old Feb 20, 2011 | 10:09 AM
toyomatt84's Avatar
Sanji
Default Re: Quick Offset Question??? 15"x6" wheel
Both the 15x6 +35 and 15x6 +40 will fit without complications, given you're using properly sized tires and aren't so low that your oil pan mates with the ground.
Old Feb 20, 2011 | 10:21 AM
dpetro1's Avatar
i dont see why any of those sizes wouldnt work. stock gsr blades are 15x6 +45 and clear the front brakes just fine.
Old Feb 20, 2011 | 10:27 AM
Turbo O's Avatar
I was also thinking that but was not 100% sure.
and I have no idea what the customer did installing since I was not there.
Maybe he is just bullshitting me to make small talk?? idk
MJobe
Honda Civic (2006 - 2015)
12
Nov 3, 2009 07:13 AM
bbRedSi
May 6, 2007 11:38 PM
Circuit Star-29
Sep 17, 2006 03:21 PM
Takeoff
Jun 4, 2002 06:49 AM
