Replacing the rear metal brake fluid lines on accord LX 1993.
Old Feb 19, 2011 | 09:36 PM
emicha1's Avatar
Default Replacing the rear metal brake fluid lines on accord LX 1993.
Shouldn’t they be the same length?
Thanks
What is the Min. front brake disk thicknes? on Accord 1993 and Civic 2001?
Old Feb 20, 2011 | 05:09 AM
poorman212's Avatar
Default Re: Replacing the rear metal brake fluid lines on accord LX 1993.
When replacing the metal/hard lines, yes they need to be the same length and diameter. I would suggest using poly coated lines.
Old Feb 20, 2011 | 05:13 AM
phootbag's Avatar
Coat the lines in a thick white lithium grease to keep them from rusting again. I moved from a state that doesn't salt to a state that does and the first thing I did was spray the hell out of my car.
skydrvr
Jul 6, 2017 07:11 AM
Superorb
May 30, 2006 09:00 PM
