h22a timing belt???
Old Feb 19, 2011 | 04:52 PM
accordmatt's Avatar
Default h22a timing belt???
l just did a jdm h22a swap in my 96 accord was driving fine and cut off right as l got home. checked everything then pulled valve cover. timing belt had walked over to the right and shredded the far edge. l turned crank over to see if it jumped timing and made a small bubbling or noise like air or something. but arrows on cam gears still look like they were ok. considering it just cut off and was driving since that could it have done anything internally? or should l be good just replacing belt and double checking timing?
Old Feb 19, 2011 | 08:34 PM
sde780's Avatar
Default Re: h22a timing belt???
Did it skip teeth? If it did you probably bent some valves
withoutlimitslude
Jul 19, 2010 02:58 PM
jerryscherry
18
Mar 24, 2010 10:37 AM
Metal Head
Sep 7, 2008 07:10 AM
DarkBB4
Feb 13, 2006 06:40 PM
DC5_R
Jul 7, 2003 06:30 PM
