2002 Accord Water Squirter not working
Hello all. I have a problem that has been bothering me for some time now. My '02 Accord's water squirter does not function. I pull the lever and the motor does not work. I replaced the motor and still nothing. I suspect that it may have something to do with the wiper switch since the intermitting wipers don't work as well. Has anyone ran into this problem before? Any input would be beneficial.
Thank You
VonChahe
Thank You
VonChahe
Did you check for 12V power at the washer motor plug when the washer switch is triggered? If the motor isn't getting power, chances are that you have a bad wiper/washer switch or a broken wire somewhere.
Officer
Mar 3, 2008 04:49 PM
