P0F ecu still swap pins?
I put an obd1 jdm h22a in my girls 95 accord with an p0f ecu do i still have to swap pins a6 with a11? The accord harness is the reason for the switch but the ecu came out of an h22 accord. I would think i wouldnt have to swap the pins out, can someone help confirm this?
thanks
thanks
Only one way to find out is to plug that new ECU you got and see how the car runs. If it runs rough with a CEL then yes, those two pins will need to be swap.
No, pin swapping is not needed, I do recommend blocking off the EGR valve with the p0f ecu, the parameters are different and it wants to open at a lower manifold pressure, which can lead to a poor lower rpm operation.
