Custom Bracket for Fuel Pressure Regulator
So I've been wondering where to put my Fuel Pressure regulator and tonight I finally figured it out! So as most of you know I've been tucking my engine bay so I've been trying to keep the FPR in a place where I can adjust it if needed yet tucked.
I found these two threaded holes behind the valve cover... I don't remember what they went to but I figured I could use them!
(sorry forgot the flash)
I couldn't just use the bracket with the FPR and only one bolt... so I made my own bracket! Ironically I found this piece of metal lying around from my custom throttle cable brackets
First thing first clean up all the edges!
Now I mark the first hole and drill
And now to test out how it sits currently
BADASS! Now to mark the next hole
I then drilled the top hole and also shaved some of the bottom I didn't need and rounded the top to match the curves of the bracket better
Now lets test it out and bolt it down
Not bad... now for the real test! Add the fuel pressure regulator!
and how it looks from the front
It's to late at night but I plan on painting it black to match the bracket and FPR!
Took me about 45 minutes to make this and figure it out.
Good placement for it. Normally I've seen people mount it on the driver side shock tower (usually with k-swaps in DC/EG chassis), but I like this better. Good work man
