Sometimes the stick doesn't go in to 1st gear.
I drive a manual. Sometimes when I'm at a stop and the light turns green the stick doesn't go in to 1st from nuetral. So I press down the the clutch pedal again and usually the second try gets it in there. Its not that bad because it doesn't do it too often, but why could this be happening? Is there anything moderately easy I could do to make this stop happening?
Really? Well if its normal for that to happen at a complete stop I will. I've known its supposed to do that if I'm at too high of a speed to down shift.
oh wait, i totally didnt read it right...i thought you were coming to a stop light, not taking off from one...hmmm i couldnt really be able to tell you then
bump for the right answer
welll id check your tranny level fluid first then from there hmm i think it was syncro's or youur cmc (clutch master cylinder) or slave cylinder but that would be 4th
Mine does the same after I installed my PSPEC short shifter. It won't go in gear at a dead stop. I always have to pop it into second and back into first before the green light hits; I got use to it doing it this way. Lol. I know it's not my slave or master clutch cyl nor the trans fluid because it did it to my F22B1 and on my H22A. My believe that it might be the shift cables may be binding, because thats the only thing I didn't change out when doing the JDM H22A swap.
Its honestly not that bad. It only does it like twice a week, its just a little annoying when there is a car directly behind me. All its going to take is for somebody to not be paying attention.
Selecting another gear, allowing the car to roll slightly, or letting out the clutch pedal and then pushing it back in will rotate the shafts slightly and allow the synchro teeth to line up so that the shift fork can slide it onto the gear.
There is no way to prevent this from happening on occasion. Even a brand new transmission will do it.
Now, if you're having this problem every time you try to select a gear, it indicates that you may be having some sort of problem - depending on behavior, possibly a clutch problem, a hydraulics problem, a shift linkage problem, or an internal transmission problem.
It's completely normal. The synchronizer teeth do not always line up exactly even with each other when the transmission shafts come to a stop. Occasionally, they will stop in such a position that it blocks the synchronizer from engaging the gear.
You can put the gear in 1st and keep the clutch pedal pressed down before the light turns green: this gives you more time to get in gear. With most of the cars having manual transmission here it is common practice (especially when your car is the first car at the traffic light).
Holding in the clutch pedal puts excessive wear on the throw-out bearing. This will lead to premature clutch failure.
That would be my thoughts on that, especially since the transmission is stock in a 20 years old car.
This is probably what is going on. Ever try to go in reverse and it won't go so you have to either let it roll or pull up some then it will go in reverse? I would assume this is pretty much the same thing
KashMillien
Jul 22, 2016 10:02 PM
suspendedHatch
Transmission & Drivetrain
Aug 24, 2009 05:00 PM
SiRkid
Sep 21, 2008 09:12 PM
