ef hatch pops fuses when key is turned to prime fuel
Old Feb 18, 2011 | 11:13 AM
OneSloEk9's Avatar
Default ef hatch pops fuses when key is turned to prime fuel
i installed an obd0-obd1 jumper harness into my ef hatch, plugged everything in exactly how i was told to do and i have a PO6 ecu u plugged in. when i turn the key to prime the fuel pump, it pops a fuse every time. im running obd1 injectors and the distributor is obd1 as well, but im using the original engine harness with distributor jumped as well. does anyone have any ideas on what is wrong??????
Old Feb 19, 2011 | 09:38 AM
Edwin909's Avatar
Default Re: ef hatch pops fuses when key is turned to prime fuel
did you remove the resistor box for the obd0 injectors?...
Old Feb 19, 2011 | 09:40 AM
2point2's Avatar
Where did you get the jumper harness?
Old Feb 19, 2011 | 02:39 PM
tonythetuner®'s Avatar
Sounds like a short some where brake out the volt meter and do some testing
efruby
Classic Hondas
Mar 28, 2016 03:08 PM
em1effekt
11
Jan 21, 2012 05:37 AM
ef4real
Mar 19, 2011 03:36 PM
ThatEFinGuy
May 19, 2009 08:26 PM
BLUE EH3
Feb 16, 2007 06:28 AM
