Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2 questions...civic radio + changing gears
Old Feb 18, 2011 | 10:48 AM
jaesun's Avatar
Default 2 questions...civic radio + changing gears
So I now have a 2009 Civic LX-S (bought Certified Used). 22k miles, Auto, Stock car (nothing aftermarket changed)
Driving it around, I seemed to have noticed 2 things.
1. The radio. It seems to change volume on its own as I drive? When I am stopped or going slow, the volume is lower, but then when I get to certain speeds or higher (45MPH+) the volume seems to be higher. I don't have the owner manual that comes with the car, so not sure if there is some feature that changes the volume based on speed?
2. It seems, that when I change gear (usually from Reverse to Drive), the transition to drive seems to be "rough". It seems to happen mostly with a cold start (first drive in the morning, or after going home from work). Seems more pronounced in this car than any car I have driven before. Any other owners get this?
Thanks in advance. Other than this, the car seems great!
Old Feb 18, 2011 | 12:18 PM
av911's Avatar
Default Re: 2 questions...civic radio + changing gears
1. SVC.
2. Normal. The ATF is still cold. If needed, change ATF.
Old Feb 18, 2011 | 01:23 PM
jaesun's Avatar
awesome, ty.
Old Feb 18, 2011 | 02:24 PM
TheMuffinMan's Avatar
He knows where you live!
I would check the transmission fluid level and then have the transmission fluid changed out with Honda ATF
Awdcrvbburford
Honda CR-V & Element
Mar 31, 2018 06:10 PM
Mychal71
Jan 3, 2012 04:17 PM
AccordDemon
Oct 27, 2005 01:21 PM
CrAzyGsR101
Mar 22, 2005 12:36 PM
Silver_Rex
Nov 30, 2004 04:53 PM
