purchasing T3/T04B tomarrow in great condition, what else will i need for the set up?
Old Sep 25, 2002 | 03:37 PM
MysteryWagon's Avatar
Default purchasing T3/T04B tomarrow in great condition, what else will i need for the set up?
it is going on a 1st gen B16, what else will i need to be safe with the engine since it is stock?
any good fuel set up ideas.
i need to get a mani can't decide on getting equal length made or buying a revhard or drag.
on my list so far,
-intercooler piping
-intercooler
-tial35mm
-all the nessesary lines, where i will need your help on.
-what is a good fuel pump?
-should i get injectors if my goal is only 8lbs?
-what else guys, i am blank when it comes to putting my own kit together.
i need to try and stay under $2000, but if not possible , like say equal length is envolved then that is ok.
i might even try and swing a victorX manifold.
this will be greatly appriciated
ps. has anyone ran a T3/T04B on there B16'a
thanks
Justin
Old Sep 25, 2002 | 04:31 PM
Jared's Avatar
Default Re: purchasing T3/T04B tomarrow in great condition, what else will i need for the set up? (MysteryWa
-intercooler piping: jegs
-intercooler: starion? depends on what your plans are
-tial35mm
-what is a good fuel pump? walbro, cheap and works great
-should i get injectors if my goal is only 8lbs? DSMs
-what else guys, i am blank when it comes to putting my own kit together: V-AFC, and an FMU, I suggest 12:1, very easy to tune with the VAFC, also you'll need all the necessary flanges and gaskets, give turbonetics a call
Old Sep 25, 2002 | 05:25 PM
TURBOSALES's Avatar
we have all the flanges you need, in stock.
also, what is the turbine size on the turbo you are picking up and how much are you paying.
for street driven b16's with lower boost (10lbs or less) i've seen good results with the .48 a/r stage 3 wheel turbine, the .63 a/r is a little too laggy on the 1600cc motor.
we have the t3/to4e 60trim compressor, .48 a/r turbine in stock. spools way fast on the 1600cc. only $625 shipped
or we have just the turbine housing for $159 shipped if you pick up the turbo your looking at and the turine housing is too large, it might be cheaper for you this way.
sorry for the long post, just trying to make sure you get the right turbo for your application.
hope this helps
Old Sep 25, 2002 | 05:32 PM
SiRkid's Avatar
.63 laggy? hardly
.48 tends to die out up top on the b16
Old Sep 25, 2002 | 07:04 PM
could you dirrect me to a nice place for the walbro information and FMU's.
thanks guys
Justin
ps. i am getting the T3/T04B for $250 from a friend, so i know what car and who it is coming from it is in great condition and does not have anything wrong with it, it came off a Prelude h22a that is built, so he wanted larger turbo.
Sirkid, you live in memphis don't you , is your car running yet? dident you have a bad tranny or something in that nature?
[Modified by MysteryWagon, 12:05 AM 9/26/2002]
boostedteg4dr
Apr 7, 2008 06:52 PM
VTEC IS UR BEST FRIEND
Dec 12, 2007 04:26 PM
95BlkGSR
Nov 16, 2004 05:02 PM
sidan
Jan 7, 2004 07:24 PM
93B17A
Feb 15, 2002 07:36 AM
