overheat n squeak
Belts are probably squeaking because they got wet. You might replace your thermostat just to make sure that isn't why it's overheating. Make sure coolant is topped off too. I can't think of anything that would over heat due to getting something wet.
My car just started overheating recently to. In stopped traffic Ive seen it at 3/4 scale on the temperatrue gauge. I turn the heater on full blast and get moving and it goes back to half scale like instantly. I just topped off the coolant a couple days ago to and still the samething. Im thinking either the thermostat or im leaking coolant.
2. Battery positive to one terminal of the connector.
3. Body ground to the other terminal.
*NOTE: Doesn't matter which terminal as it will just spin backwards.
And, yes, the fan should come on after a few minutes of idle at operating temp.
Rein4st
Apr 7, 2012 11:17 AM
confucius
Oct 23, 2002 02:46 PM
