ICM Replacement 95 GSR
Old Feb 17, 2011 | 05:06 PM
Ranilla07's Avatar
Icon2 ICM Replacement 95 GSR
Greetings:
I am trying to replace the ICM on my car and it appears as though it is being held in by a screw inside the housing? I'm not totally sure what its called. I do know that the ICM won't budge and I'm positive it is because of that screw. Any tips on getting that screw out? I have pics or can take more if needed please let me know. I need to have this thing fixed by Monday morning.
Thanks
Old Apr 21, 2011 | 08:34 AM
daver's Avatar
Default Re: ICM Replacement 95 GSR
i'm having the same problem, did you solve this? some ICM's are held in by 2 screws at the top and come out easy, but others only have one at the top, so there must be one inside that we can't get to.
Old Apr 21, 2011 | 11:18 AM
fcm's Avatar
fcm
Old Fart
Once screw(s) are removed and leads are unplugged it should jut pull straight out, this may help... http://www.angelfire.com/ca/DrOhm/di...torRepair.html 94
Old Apr 21, 2011 | 12:39 PM
daver's Avatar
I found it, there are 3 screws on this design, or should i say 1 screw and two bolts. There are actually two on the outside of the distributor housing, which i found when i pulled the distrib off. This design has only the one screw inside, where everyone says there are two screws..
Old Apr 21, 2011 | 03:25 PM
daver's Avatar
the ICM was good anyway, it was the coil.. weird, 'cause it tested good... good thing i had 3 spares
CountDracura
Aug 19, 2009 11:10 AM
ImaHondaLover
Mar 6, 2008 08:50 PM
crazyteg95
Oct 13, 2004 03:07 PM
Sassafrass
Apr 24, 2003 11:40 AM
Ubermensch
Jun 30, 2001 04:48 PM
