do you need scattershield with billet case?
Old Feb 17, 2011 | 02:40 PM
cibao2ner's Avatar
Default do you need scattershield with billet case?
do guys who run billet cases need to use a scattershield? ive seen a few people who dont run them...
Old Feb 17, 2011 | 02:57 PM
redboost10's Avatar
Default Re: do you need scattershield with billet case?
yes you technically do since the billet case is not sfi spec...although most our scatter shields are not as well. but it all depends on the track i think. we never ran one and they never said anything to us at three local tracks here.
Old Feb 17, 2011 | 06:16 PM
boostedcivicsir's Avatar
Mr. Badwrench
i dont think the scatter sheilds have to meet an sfi spec, like the bell housings. they give a location, fastener, and metal thickness guidelines in the rule book iirc.
Old Feb 17, 2011 | 08:21 PM
Ls_dx's Avatar
I have the diest blanket and its got SFI specs stamped into it.
Old Feb 17, 2011 | 08:44 PM
redboost10's Avatar
deist is the only sfi scatter shield available for the b-series/d-series. scatter shields and aftermarket bellhousings for rwd trans must be sfi spec...not that it matters to us.
i talked to craig at liberty about getting the bellhousing sfi approved and he said there isnt enough of a market to go through the whole process
Old Feb 17, 2011 | 10:50 PM
wilham320's Avatar
the deist blanket is technically only certed for auto trans.
Old Feb 18, 2011 | 12:58 PM
The Show Stopper's Avatar
we run our billet case with a scatter shield for our own safety & its a nice mounting bracket for our exhaust back pressure sensors.
Old Feb 18, 2011 | 02:48 PM
SPOOLINmatt's Avatar
there is no SFI requirement for a scatter shield, just has to meet minimum specifications, its in the book yo.
Old Feb 19, 2011 | 01:02 PM
nonvtecallmotor's Avatar
IMO scattered are dumb. They "should" protect the driver and they dont. With our cars it would have to go threw the diff. area and of coarse they dont cover that area......
Old Feb 20, 2011 | 01:46 PM
josh green's Avatar
I wish someone would make a scatter shield that fit around a stock slave cylinder with a stainless braided clutch line.
Old Feb 21, 2011 | 07:20 AM
dturbocivic's Avatar
i use a golden eagle scatter sheild. it fits fine over the stock slave with braided line.
Old Feb 21, 2011 | 05:24 PM
josh green's Avatar
It doesn't fit over mine, I have it adjusted all the way forward for the most room. I am running an Earl's 10mm to -3an fitting in the slave cylinder. What are you using for hardware?
Old Feb 22, 2011 | 04:19 AM
ill take a picture for you when i make it over to the shop. im using a 45 degree fitting (-3an) there is even a .250 spacer on the backside of the slave cyl cause it hits the billet case without it.
Old Feb 22, 2011 | 05:28 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Mine fits fine as well. with the -3 stainless line
Old Feb 22, 2011 | 06:33 AM
hybrid1990crx's Avatar
I picked up a Golden Eagle shield too, however my car is not yet together.
Old Feb 22, 2011 | 06:53 AM
E Town DSM's Avatar
the fitment of the ge shield sux mazworx\ipg shields fit 100 times better
Old Feb 22, 2011 | 09:05 AM
hello1320's Avatar
Tilton T/O bearing
Old Feb 22, 2011 | 11:31 AM
tepid1's Avatar
Werd! I don't have any problems with my Maxworx shield. I had both the OEM slave and a braided cable and now I have a tilton setup.
Old Feb 22, 2011 | 12:24 PM
you dont even have a car. get back in your corner.....
here are the pictures
Old Feb 22, 2011 | 04:36 PM
josh green's Avatar
Oh okay, you guys are using the 1/8' NPT fittings over the 10mm. Unfortunately they don't make the 10mm in a 45, I wound up spending another $15 on a -3 to -3 swivel 90 to make this work.
zakura R
Mar 20, 2013 05:55 PM
99blackdc2
Transmission & Drivetrain
Oct 5, 2012 06:54 PM
b18c inside
Southeast
Jul 13, 2011 10:51 AM
redzcstandardhatch
Dec 1, 2006 11:41 AM
