Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
d series transmission
Old Feb 17, 2011 | 11:07 AM
vt_hokie2008's Avatar
Default d series transmission
Will any d series transmission work for a 2002 Civic EX auto? Looking at one off of a '95 d15b7 and was wondering if there would be any issues in using this one.
Old Feb 17, 2011 | 11:17 AM
toyomatt84's Avatar
Sanji
Default Re: d series transmission
You can only use 2001-2005 Civic transmissions on a D17. It's an entirely different management system.
Old Feb 17, 2011 | 11:23 AM
Well that sucks. Thanks for the info!
Old Feb 22, 2011 | 01:11 PM
b0yg0tskills's Avatar
My manual trans on my 01 lx is going bad. Still drives but it makes a lot of noise at idle until I step on the clutch. I already had my clutch replaced not to long ago and it was still making the noise. The shop just said it was my throw bearing which I'm guessing they didnt check for the noise at all. I've read some where that it could possibly be my shaft bearing?
Old Feb 22, 2011 | 01:17 PM
It Wasn't Me's Avatar
When they replaced the clutch, it would (should) have included a new release bearing and pilot bearing.
Old Feb 22, 2011 | 01:20 PM
toyomatt84's Avatar
Sanji
Your throw-out bearing could very well be the culprit behind the noise.
Old Feb 23, 2011 | 07:49 PM
Could you explain culprit a bit more?
Old Feb 24, 2011 | 01:59 AM
toyomatt84's Avatar
Sanji
cul·prit
   [kuhl-prit]
–noun
1. a person or other agent guilty of or responsible for an offense or fault.
2. a person arraigned for an offense.
Basically, the culprit is the "cause" of something.
Old Feb 25, 2011 | 06:17 AM
Matt, I know your from the Midwest area, possible for you to take apart my lame trans and look at it? I'll come help!
Old Feb 25, 2011 | 08:53 AM
GriFFIthS's Avatar
If the noise goes away when you push the clutch pedal to the floor then its not the throw out bearing, your problem lies in the Input shaft bearing inside your transmission.
Its common.
If the Noise develops as you push the pedal to the floor then the problem is most likely the throw out bearing and not the ISB
95Hatch_209
Nov 2, 2015 12:52 PM
akacoke
Jun 27, 2011 10:48 AM
93 EG
12
Mar 3, 2007 08:14 AM
00siandrew
Apr 13, 2006 05:09 PM
SiKSiR
Mar 14, 2002 06:59 PM
